I need your technical help here guys.
In terms of valves and port sizes, are the RB25DE (R32) the same as RB20DET (R32)?
I have the rare RB25DE from a R32 and was wanting to bolt this up to RB30, but was wondering if id be better off bolting the RB20DET head instead of the larger capacity in the RB25 means they are the same?
Thanks in advance gents!
https://www.sau.com.au/forums/topic/415650-rb25de-head-same-as-rb20det/
Just the first 4 numbers tell you its totally different
RB25 vs RB20 = two totally different engines, that means both head AND bottom end.
RB20 on a RB30 is a total waste of time, better off sticking with the single cam.
