Hey all,
Wrecking an r33 series 2, 2 door, turbo, manual. It has had a major collision in the rear end, so most of the rear is completely screwed. i have made a rough list of the parts and prices i want, if there is something you want and its not on the list just ask. The motor, gearbox, tailshaft, loom, ecu, steering rack and front control arms are all mine. Everything else is for sale pretty much. The fmic is sold already and the lights and front bar are gone too.
(Driveline/engine)
rb25 turbo (good cond) 250
Rb25 manifold 50
Rear subframe 100
Diff 200
Driveshafts 50
HICAS 50
Power steering bottle 20
Brake master cylinder 50
Sway bars 20 each
Front wiper motor 20
Rear Wiper Motor 20
Steering column 20
Manual Conversion parts(pedals, etc) 50
300zx pair of wheels, rims are good, f**ked tires $50
s15 pair of wheels, f**ked tires and many scratches $50
Standard r33 suspension $50
(Body parts) WHITE
Drivers door mint 150
Bonnet (1 small ding) 150
Front Guards mint 150 a pair
Type m skirts (front piece inside the wheel arch on the pasenger skirt is cracked and missing a piece out of it, still looks good from the side) 100
(DASH PARTS)
turbo cluster with 170,xxx 50
Dash good condition 150
Glove box 20
Center console missing manual shifter insert 50
Heater core 20
Aircon core 50
Heater fan 20
(INTERIOR)
Front seats (r33 4 door) 50
Rear Seat (r33 4 door) 50
Indicator/wiper switch assembly 50
Handbrake lever 20
Rear trims 50
Seat belts set of 4 50
Carpet fairly good condition 50
Roof lining 40
Skyline Skuff plates, both sides 35
Door seals 25 each
Boot seal 25
Rear ¼ trims 25 each
Rear1/4 window surrounds 50 each
A pillar Trims 20 each
B pillar trims 20 each
Rear Vision Mirror 20 each
(ODDS AND ENDS)
Fuel tank 30
Fuel pump 30
Windscreen 50
Rear window 50
wipers 15
Engine Mounts 50
Handbrake assembly & cables 50
Guard liners 75 for all 4
THIS PRICE LIST I GOT OFF SOMEONE ELSE ON HERE AND ADJUSTED THE PRICES HEAVILY BECAUSE I THOUGHT THE PRICES WERE WAY TO MUCH, THAT SAID, SOME PRICES ARE SLIGHTLY NEGOTIABLE, AND IF YOU BUY MORE THAN A FEW PARTS I WILL PROBABLY DISCOUNT IT.
PLEASE CONTACT ME ON MY MOBILE LISTED BELOW AS ITS EASIER THAN f**kING AROUND ON HERE, THANKS.
Pic: No point putting up pics as we all know what an r33 looks like, can get close ups of certain parts if you want.
Location: Laverton North, will ship some parts at buyers expense.
Contact: 0407 056 817
Edited by Jack_Sky
all those parts are gone guys.....
Albie please READ the post before u ask questions about parts....
DRASTICALLY REDUCED PRICE DROPS ON ALL ITEMS I STILL HAVE! COME GET THESE PARTS. WILL THROW PEOPLE STUFF FOR FREE EVEN IF YOU BUY OTHER PARTS. IF NONE OF THIS STUFF GOES IN THE NEXT 3 WEEKS IT WILL BE CRUSHED WITH THE SHELL....
rb25 turbo (good cond) 100
Rb25 manifold 25
Rear subframe 25
Diff 150
Driveshafts 50
Hicas $25
Sway bars 20 each
Rear Wiper Motor 20
(Body parts) WHITE
Drivers door mint 100
Front Guards mint 100 a pair
Type m skirts (front piece inside the wheel arch on the pasenger skirt is cracked and missing a piece out of it, still looks good from the side) 80
(DASH PARTS)
Dash good condition 80
Glove box 20
Heater core 20
Aircon core 20
Heater fan 10
(INTERIOR)
Rear Seat (r33 4 door) 20
Indicator/wiper switch assembly 20
Carpet fairly good condition 20
Skyline Skuff plates, both sides 20
Door seals 10 each
Boot seal 10
(ODDS AND ENDS)
Windscreen 25
Rear window 25
Engine Mounts 25
Guard liners 50 for all 4
  • 4 weeks later...
Still have these parts left over and maybe a few other little things.. taking the car to scrap this week probably so let me know if u need anything. nego on the prices listed. Rear subframe
HICAS
Sway bars
Front wiper motor
Rear Wiper Motor
Steering column
Radiator
(Body parts) white
Drivers door mint
Guards mint
Type m skirts(chunk missing on front wheel arch, need repair)
Type m pods(fiberglass, slight damage, need repair on bottom)
(DASH PARTS)
Dash good condition
Glove box
Heater core
Aircon core
Heater fan
(INTERIOR
(OTHER)
Fuel tank
Fuel pump
Windscreen
Rear window
wipers
Engine Mounts
  • 4 weeks later...
 Share
    • The Daily - 2011 Audi A5 And the camper VW transporter T5
    • Wow mate that's huge, congrats. Glad you found better people to deal with and all seems like it's going in the right direction.
    • The best setting for street is what gives the best tyres wear for your driving style Different tyres like different camber You want the whole surface of the tread to wear flat, if the inside of the tyre is wearing more than the outside reduce camber settings For toe, have the minimum amount to give the handling you want Caster, from my experience if you can adjust it, is as much as you can get without clearance issues And while -2.5° of camber on the front might work well with good tyres for "spirited" cornering, it may be too much for a street car Lots of front camber will effect braking Just like to much rear camber will effect rear traction (rwd), and braking  When I set my Bogan Cruise Ship (VX SS) up for drags I tested how much tyre width I actually had in the rear by doing a hard launch (skid), it originally had -1.5° in the rear, and you could see that the tyre wasn't putting down alot of the tread, I maxed out the settings to get as little camber as I could with the OEM adjustment and some camber bushings and got it down to just under -0.5° with 0 toe, that gave me a fair bit more "rubber on the road" and helped it hook up for my 60' and my 0-100kph And with -1.5° in the front the big old boat handles fine on the street and my tyre wear is nice and even on both front and rear tyres (currently Hankook RS4's) As for semi slicks at the track, again, it depends on alot more IRT the suspension, the track and lots of other things, so, I'll leave that up to people who have more experience, especially with a AWD In saying this, street settings are pretty easy, just look at the tyre wear Meh, Necro thread, it's late at night, and I has been drinking beer
    • Thought I'd give an update. There needs to be scarce details in some areas due to ongoing discussions. Here's the journey of trying to make the booked registration appointment (again). Sent a complaint to Car Inspect outlining the concerns and made some demands. Went to a service center in Geelong, got assaulted with bullshit items on the RWC, as you know. Tried to quote $2.5k AND wanted a structural report Only seemed to be one place around Geelong that does them, they demand $495 just to end up telling me it's f**ked, at least $11k to fix and tried to sell me his own Skyline in the process (bro, wtf?) Started stressing about what I'm supposed to do with this possible pile of steel. Awaiting that, I was sent an angel friend who works in Melbourne and knows real mechanics and body shops.  They laughed at the reported quotes (don't get work done in Geelong) Car underwent some front surgery and brought back better They then sent it to the mechanics for RWC Registration appointment is two days away at this point. Mechanics pointed out two issues: driver's seat and shocks - that's it. He offered couple options and I chose coilovers. Frantically I scoured the jungle realm that is Facebook Marketplace (again). Found what looks to be a decent Series 1 seat actually - $100 Guy is friendly, offers to bring the seat with a colleague who's heading to Geelong (thanks man, that was cool) Seat arrived, looks good. Throw it in my car and drive to Melbourne and drop it to mechanic T-1 day, mechanic reckons job will be done for the fronts only, gets it done by 4PM Mechanic heads to get the coil-overs that night as a favour to help me make the appointment Get driven to Melbourne, drove the car back - RWC Unlocked! ✅ VicRoads tomorrow, the goal is close now. 🙂
