  • Replies 40
Hi Mate im after some panels if the paint is good on them drivers door, side-skirts, passenger guard, boot and spoiler
also few interior bits will pick up today!
aftermarket cams?
Sorry mate no aftermarket cams
Keen to take the Cat off you right away, hows the quality of the core? cheers
Core is in great nick, no damage. PM sent
  • 3 weeks later...
Have you got the s1 drivers side window motor
PM sent
Can I get the top intercooler pipe the bit to the throttle body ? And interested in the bonnet
Sorry all the piping and the bonnet are sold !
Hey mate still got the stock suspension?
Sorry mate they're gone
  • 2 months later...
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
