So keen to see the suspension work happen! Can't wait ants!
me too Zac. However after speaking with Gary aka sydneykid it will be a nice package for sure. But it ain't cheap so I'm in saving mode FTM but in a few weeks we will see some suspension drool ;)
Today was a big day and got lots done.
First up the rear wheel arch got some TLC
post-5053-13955677177786_thumb.jpgsmoothed out all the dodgy spot welds
post-5053-13955677657172_thumb.jpgthen I filled in the gaps with some selleys autofix to ensure no rust decides to set in
post-5053-13955678763059_thumb.jpgpretty handy stuff
Then preparation time.
I wiped the wheel arch with some prep wash to remove any dirt and grease
Then more preparation work
Got my big trusty making tape out and.....
neatly taped around the wheel and inside the wheel arch as well
Then I attached some newspaper to protect the inside from any unwanted paint spatters. I also covered the rear brakes with an old work shirt that I no longer use
Now we are ready for painting :)
I acquired this paint can from super cheap and is the recommended paint for Nissan between 1984 onwards
Nissan crystal white yeah
Next step was to get RHS N1 side-skirt back on
Photo of corrected bodywork without side-skirt just for the hell of it
I then gave the side skirt a quick wipe down from all the dust it had gathered the past few months and then applied som Sikaflex
Next I gently made sure I put the side skirt back to where it belongs
On the car ;)
Again I used clamps to ensure the side skirt sits flush against the car
The excess Sikaflex will eventually just be peeled of after it's dried
Like so
The car is finally starting to come back together
  • Like 1
I also thought I would take the opportunity to follow a trend happening with some builds FTM
and detail the inner door cards with
CARBON VINYL WRAP!
Do first up
Clean you're door card as it has collected a fair bit of dust over its time
Then unscrew the back of the inner door pocket
Make sure you don't remove the factory glue at the bottom of the inner door pocket card
I got hold of some 3M carbon vinyl wrap from eBay for about $36 but you.can get it from super cheap about the same price the length I got it for
Then just measure and apply carefully
You do not need to cover the entire infer door card as the edges are not visible with the inner door card
I also wrapped the side open edge for more strength but is not mandatory
Then just bolt everything back up and admire you're work
That's it for now.....more to follow soon :)
  • Like 1
Lookin good mate, seeing how good yours has come up is encouraging me to clean mine up, so thanks :)
Also another door card win. Definitely a cool craze happening ATM, I will be doing this too lol
Just few more pics of before after bodywork / body kit correction just the hell of it
Thanks for putting up how you did your side skirts. Give me a much better idea how to do mine, come time!
Fantastic work.
Looks so much better!
  • Like 1
Fantastic work.
No worries Shivam. That is what its all about ;)
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
    • Well the articals keep saying a Q50s (Skyline in Japan) with a new Manual gearbox. I like the talk about the new looks with the round tail lights. I hope they bring back the retro look like they did with the Z
