From what i have seen on my 32 gtst... no.
The big sensor is for the ecu, the small one is for the dash temp gauge.
Your fan sensor would have a different signal voltage for a given temp. You could test this with cold water, hot water, an accurate thermometer and a multimeter.
The sensor in the bottom of the radiator is something to do with aircon i think not 100% sure, its not a good location for engine temp control as its after the water is cooled by the radiator.
Its a pain to take off the manifold and either tap one of the existing holes or drill and tap a new one. So i just got one of those bits that goes inline with the top rad hose and you can put a sensor into it. They are usually 1/8 npt. Thermo control sensor may be bigger so you might have to drill and tap, you just have to decide where.
My thermo control is still not set up, i just have a good temp gauge and a switch in the cabin.
As above, you can't use either thermo sensor from the RB20. And the Z radiator doesn't have the sensor in the bottom of the radiator.
The thermo fan should come with a sensor and rheostat. The sensor normally fits in the top radiator hose where it connects to the radiator.
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
