  • Replies 53
My understanding for ACT rules regarding FMIC:
If your vehicle was fitting with an intercooler mounted anywhere on the front of the car (side-mount counts) then you're perfectly within the rules to change to a proper front-mount intercooler provided that you didn't need to modify the chassis (cutting hole for return pipe) or reo bar in any way. Obviously it has to be mounted properly. Dickson had no problems with my front mount, and I don't believe it was noted on the engineer's report (well, at least not in the same way my turbo/suspension etc were).
https://www.sau.com.au/forums/topic/416453-defected/page/2/#findComment-6686634
Nope, only if it's newer than 10 years old. Just went through the process with my daily driver.
If its only there for a history check wouldn't they just need the vin etc not to look at everything on the car though?
Because I thought you only did the history check etc after you got a rwc for interstate cars?
I'm thoroughly confused on it!
https://www.sau.com.au/forums/topic/416453-defected/page/2/#findComment-6686684
No idea! I'm just sayin to transfer my Beema from NSW rego to ACT rego all I had to do was go get it inspected at any authorised workshop (which I did) then took the paperwork to dickson with the old plates. Signed some shit, got new plates and was done.
Was very easy. It's nice to have one car that is straight forward!
https://www.sau.com.au/forums/topic/416453-defected/page/2/#findComment-6686911
All I had to do for the GTR was get it inspected at Ultimate Tunes then go to Woden hand the old plates in and get the new. Maybe because the car was older than 10 years?
I have to do my 2004 XT Forester in February so will be interested to see what I have to do for that.
https://www.sau.com.au/forums/topic/416453-defected/page/2/#findComment-6686948
Yeh for some reason you only need the history check if it's less than 10 yrs old.
I don't get why they need you to go to Dickson for it though...
The idea behind the ID check is that its supposed to check that the car hasnt been rebirthed or anything
https://www.sau.com.au/forums/topic/416453-defected/page/2/#findComment-6688390
Well that's a kick in the grundle then isn't it.
Is there anyway to avoid the Dickson history check with a newer 2nd hand car? Like getting documents which show it's history from car dealer and previous owners etc or something along those lines?
Why must they be such douchebags...
https://www.sau.com.au/forums/topic/416453-defected/page/2/#findComment-6689019
before putting all this fear into the masses.
They actually do their job, just sometimes it seems over zelous on the imports and modified vehicles.
My main gripe is that alot of our cars are ALOT safer than most shitters on the road. Yet we appear to be the centre of their target (ing).
https://www.sau.com.au/forums/topic/416453-defected/page/2/#findComment-6689158
Ahh, but they also have a habit of choosing when and when not to 'do their job' by selectively ignoring certain things....as well as not even knowing their own tech standards they should be following half the time. lol
https://www.sau.com.au/forums/topic/416453-defected/page/2/#findComment-6689193
    • Neg, the top one is actually for the front. The sizes are 18x10.5 +18 and 18x11 +32.   I measured many times but I'm sure I'll have problems as this is the thread for problems.
    • Just one thing; tapping tapered threads is tricky. Taps are always tapered and you would generally run it as far as you can, but with a tapered thread you have to stop much sooner otherwise the wide part of the taper will run in too far and you will have to thread the sensor in too far too as well (possible that it will never make a good seal) BTW nice wide wheels, I guess the top one is for the back!
    • Welp, good to know. Will have to wait awhile until steady hands with drills and taps are available. In other news, these just arrived! I will weigh them for posterity. Edit: 11kg each (or 10.9/11.1 depending on what my scale decides over multiple tests, the 18x11 don't seem to weigh noticeably any more than 10.5)
