  • Replies 53
My understanding for ACT rules regarding FMIC:
If your vehicle was fitting with an intercooler mounted anywhere on the front of the car (side-mount counts) then you're perfectly within the rules to change to a proper front-mount intercooler provided that you didn't need to modify the chassis (cutting hole for return pipe) or reo bar in any way. Obviously it has to be mounted properly. Dickson had no problems with my front mount, and I don't believe it was noted on the engineer's report (well, at least not in the same way my turbo/suspension etc were).
https://www.sau.com.au/forums/topic/416453-defected/page/2/#findComment-6686634
Nope, only if it's newer than 10 years old. Just went through the process with my daily driver.
If its only there for a history check wouldn't they just need the vin etc not to look at everything on the car though?
Because I thought you only did the history check etc after you got a rwc for interstate cars?
I'm thoroughly confused on it!
https://www.sau.com.au/forums/topic/416453-defected/page/2/#findComment-6686684
No idea! I'm just sayin to transfer my Beema from NSW rego to ACT rego all I had to do was go get it inspected at any authorised workshop (which I did) then took the paperwork to dickson with the old plates. Signed some shit, got new plates and was done.
Was very easy. It's nice to have one car that is straight forward!
https://www.sau.com.au/forums/topic/416453-defected/page/2/#findComment-6686911
All I had to do for the GTR was get it inspected at Ultimate Tunes then go to Woden hand the old plates in and get the new. Maybe because the car was older than 10 years?
I have to do my 2004 XT Forester in February so will be interested to see what I have to do for that.
https://www.sau.com.au/forums/topic/416453-defected/page/2/#findComment-6686948
Yeh for some reason you only need the history check if it's less than 10 yrs old.
I don't get why they need you to go to Dickson for it though...
The idea behind the ID check is that its supposed to check that the car hasnt been rebirthed or anything
https://www.sau.com.au/forums/topic/416453-defected/page/2/#findComment-6688390
Well that's a kick in the grundle then isn't it.
Is there anyway to avoid the Dickson history check with a newer 2nd hand car? Like getting documents which show it's history from car dealer and previous owners etc or something along those lines?
Why must they be such douchebags...
https://www.sau.com.au/forums/topic/416453-defected/page/2/#findComment-6689019
before putting all this fear into the masses.
They actually do their job, just sometimes it seems over zelous on the imports and modified vehicles.
My main gripe is that alot of our cars are ALOT safer than most shitters on the road. Yet we appear to be the centre of their target (ing).
https://www.sau.com.au/forums/topic/416453-defected/page/2/#findComment-6689158
Ahh, but they also have a habit of choosing when and when not to 'do their job' by selectively ignoring certain things....as well as not even knowing their own tech standards they should be following half the time. lol
https://www.sau.com.au/forums/topic/416453-defected/page/2/#findComment-6689193
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
