Hi All,
Having a 02 sensor dilema, First pic is current dodgy one in the car. Second pic is new 02 sensor.
Obviously the plugs are different. The one in the car doesn't look like it is the correct one, 4 wire plug with only 3 wires connected.
Anyone know which wire is which and how to wire up to the new one?
Cheers
Trent
https://www.sau.com.au/forums/topic/416491-02-sensor-help-c34-s1/
looks like somone may have butchered the original loom to fit the O2 sensor that is currently installed. the new one you have seems to be the stock loom setup. You have a couple of options though;
You can source the original loom connector to fit the standard O2 sensor you have bought and cut off the one you have in there already...OR.....
you can keep the same connector and cut off the new one and splice the wires together. The 2 white wires are for the heating element in the sensor and the black wire is the signal wire that goes to your ECU.
your first picture doesnt show which colours are connected to the actual oxygen sensor. IT looks like its a 4 wire connector and the green one is the only one not connected. You might want to use a voltage tester and test the wires so you know which one is which.
If you search ebay you can buy a factory style plug if you want to revert to the factory setup.
... and here is a link but you need to be careful when crimping as they are quite delicate.
http://www.ebay.com.au/itm/O2-Power-Feed-Sensor-Plug-Nissan-RB-SR-3-Pin-/220743549929
  • 1 month later...
    • Oh, forgot to add, A few months ago I was getting mixture codes and the car was using crap loads of fuel. You could smell the unburned fuel in the exhaust, it was crazy strong. Economy was over 17.5 l/100 and usually around 19. I smoked the engine and found a leaky CCV hose which I replaced and then I replaced my two pre cat O2 sensors, I also replaced the MAF. This fixed my mixture codes and improved my exonomy but I'm still 14 - 15 l/100 when pottering about town so something is still amiss. Throttle response is much better and it has more pep but I'd like to know why it's still so thirsty (and I'm hoping that whatever it is gives me a bit more poke).
    • Car is on factory injectors/z32 maf/ q45 throttle body/ z32 ecu with nistune
    • Hello all, currently finishing up a rb25 swap into my s14. Having issues with starting, car has spark (confirmed by pulling a plug and watching it spark), has fuel(confirmed by checking pulse/voltage at injectors all spark plugs are soaked in fuel). Car cranks over and pops into the exhaust with a heavy fuel smell but no attempt to start or run, I have torn the timing cover off and triple confirmed timing, turned the CAS in multiple spots both directions, attempted to start with coolant temp and maf unplugged, checked my fuel lines and made sure they weren’t backwards, checked voltage at cas/injectors/coilpacks, made sure all the grounds in the harness are connected and added a few grounding straps (1 from chassis to block, 1 from chassis to head, and 1 from chassis to igniter chip) I am getting stumped here. As a last ditch effort I made a full grounding harness tonight that’s going to run from the battery and add an extra ground from the battery onto the coil pack harness/igniter chip/ intake manifold/ Wiring specialties harness ground/ and alternator. I’m hoping maybe the grounding harness will fix it here but posting here to see if anyone has any other ideas on what else I can check. My fuel pressure is unknown right gauge will be here tomorrow.  IMG_3206.mov
    • yeah I was shocked when I checked my spare OEM on and as below that's how they come from Nissan. (side interesting note new NEO gearbox and replacement park lack the brass bush on the tips and its just all alloy) unsure about damage to the box currently back at 1110 to be pulled down/inspected and selector fork replaced as he built it previously and given the never before seen failure on his billet forks he is replacing it under warranty. He said he has used always OEM the keyway tab without issue for years so it could be an unlucky coincidence. I did talk to him about the sharp corners and stress concentration too. Re: hard shifts i got 7+ years out of the OEM one and the fork itself failed not the keyway. so could be bad luck as I said or an age thing + heat cycles in box and during fabrication of billet?
    • That's some really horrible design with the way it's cut/shaped! Is there much damage to the box that failed in? IE, new fork and you can go again, or is it a total rebuild again? Id be trying to build that piece from scratch, and getting some reliefs added in the corner to hopefully stop breakage, and then swapping boxes ASAP, and then doing the same to the currently good working box. I'm assuming hard shifts have not been friendly to it!
