Tools required - Phillips head screwdriver and 10 mm socket and ratchet attachment.
This procedure takes about 20 minutes.
STEP 1:
Disconnect the battery. Turn three plastic clips in front carpeted portion of the boot/trunk to remove this carpeted wall. Clips pop off when turned.
STEP 2:
Loosen right side bolts in location specified.
STEP 3:
Loosen left side bolt in location specified.
STEP 4:
Pry bottom panel out slightly on left side. Be careful not to break anything. Just pull it enough to allow a grip on it in the future steps.
STEP 5:
Repeat with right side. Pull slightly upwards. You may pry the panel above this one (shown to the left) out a bit if it helps- it just snaps on again. There are four hooks at the top of this piece that locate it at the top. Bolts secure the bottom, but the piece hooks into four slots at the top. ** Remember this for the reinstallation, it is the most difficult part in putting the piece back in correctly.
STEP 6:
Remove bottom piece (only at bottom of pic, the top piece need not be removed for this install so please ignore it). Put in a safe place.
STEP 7:
Remove harness from turbo timer box.
STEP 8:
Plug in harness into location shown behind ignition.
STEP 9:
Plug in the timer to the harness, and any other wires between harness and timer.
STEP 10:
Ground the black wire on harness to a location that is unpainted bare metal. The location I chose is shown below and to the left. A 10mm ratchet was used to remove the bolt here and hook up the ground wire.
STEP 11:
Hook up the battery again. Check your timer's operation now.
STEP 12:
Choose a mounting location and route your wires in any manner you choose. Secure loose wires that may intrude into the driver footwell.
NOTES:
Installation of panel is exact opposite of removal. Just pay particular attention to the part about the slots on top of the bottom panel you removed. Line up all four hooks with slots, then push the panel slightly upwards and towards the front of the car. Make sure fit is right before you screw in three bottom bolts in steps (3) and (4).
https://www.sau.com.au/forums/topic/41668-intalling-a-turbotimer/
  • 4 months later...
You need to locate the wiring which comes out of the ignition and is held onto the steering column by a black plastic tie. There is a plug at the end of this and if you have the right loom adapter for your car, it will plug straight in.
It starts getting a bit more tricky when you don't have a plug in timer and have to locate and solder wires together.
Correct the turbo timer will be installed differently if you have an alarm and immobiliser, I'd take it to a workshop to have them install it in this case (preferably the shop that installed your alarm). You will also most likely have to fork out a small amount of $$ for an alarm relay that sits between the alarm and the turbo timer as well. If your lucky the workshop might only charge you just the relay cost. :cheers:
  • 1 year later...
hey, i bought a blitz turbo timer, and when the guys installed it, all the features like, boost and automatic timer dont work.. (i have to pre set all times instead of it working it out itself)
i went back to them and they said "u didnt tell us to install the features, only the turbo timer"
WTF
anyway, to get the features hooked up, they want another $110bucks !!!!!!!!!!!!!!!!!
does anyone know how to hook up these featues ie boost and automatic timer? if so please help
cheers
  • 4 months later...
  • 6 months later...
  • 2 months later...
pictures seem to be not working, ie.
STEP 2:
STEP 3:
and as you can see, with these above steps, u cannot follow thru without pics? can someone add info to the initial DIY post, to paint apicture, so this can be done without real Pictures, or can you fix picture links?
cheers,
  • 1 month later...
  • 2 months later...
  • 1 month later...
while on the topic of installing turbotimers and alarms and the sort, i would NOT recommend AutoMotiv from sydney to do any installations. they totally FKD up my alarm and fried my turbo timer, and wont fix anything coz they claim the original turbo was wired wrong (yet stupidly they still wired straight into it anyway). so now i have a c car with a fried alarm and turbo timer...f'ing pricks. id never go back there...
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
    • If there's oil in with the clutch, I hope it finds its way out even if that hole has a cover/grommet 😛 I don't want oil near my cars clutch! 😛 Interested to hear the answer about covering it, I'm assuming a bung for a gearbox from another car that has a grommet to suit.
