  • Replies 55
I wouldn't exactly say I'm hanging out for it :D But yeah, I'm keen. Add to that the fact that next weekend is totally out for me! Fri/Sat I've got my daughter, and Sunday is the drags.
prpbably bout 3 weeks maybe june 13 or 20? ive got to go down there and see when we can book the track. ill keep everyone informed.
Hey Mark you decided if your getting rid of your 2 17"wheels yet? would come in handy for the drags
Cheers Matt
U want em ring me or ill speak to u at work. Im gonna try and get some tyres tomorrow so u will be able to grab them on the weekend. Work something out then.
update, the dates avaliable for the karts are 4july any time at this stage and 11 july also any times at this stage.
if we have 14 drivers cost is $50
if we have 16 drivers cost is $46
cheers Matt
I think we should have another poll for those dates again :)
and the one with more votes wins
BTW I can't attend on the 4th, my mate is getting engaged on the independent day :) If we could have it on the 11th of July in th evening, I'll be in for sure.
cheers Matt
can u make it 3 july??? i am leave adelaide for holiday at 4 july!
    • New CAS just turned up from NZ Wiring. Looks like a nice bit of gear.  So, yeah. Triggered, bro. Realised I may as well do the cam belt while mucking about with it so will order one of them.
