Did a quick search, to no avail. Sorry if this has been covered, and my search skills are just lacking, but i could only find RB26 info.
Basically after a new dump pipe for RB20/25 standard exhaust housing (its a hiflow). Wanting a short dump if possible, similar to the factory one so i can reuse my front pipe, due to it having a flex pipe welded in which i wish to retain.
I fitted a cheap stainless split dump about 2 years ago, and immediately noticed it was harder to control boost steadily compared to the stock dump, but could never be farked refitting the stock one so i've just put up with it since. I am aware of the HPI bell mouth style ones which look like a good bit of kit, but $500 seemed a tad excessive to me. Is there any other options out there, what have you had luck with/ or are currently using, or should i go back to the standard dump (only @ 200rwkw)?
Opinions/info greatly appreciated guys! Cheers.
https://www.sau.com.au/forums/topic/417304-need-a-dump/
Just Jap. Get the full length bellmouth** one, and take your flex joint out. Simply not needed on an inline engine. Goes all the way from turbo to cat.
** I'm just recommending the bellomouth because the dump Nazis here would scream at me for recommending the Just Jap full length split, which I have and think is better.
https://www.sau.com.au/forums/topic/417304-need-a-dump/#findComment-6697090
Haha, cheers for the reply mate. That's fair enough. The main reason i was wanting the flex was that the car has a hacka-tig-together 3" stainless import spec one piece exhaust, which has the cat flanges welded on in a stupid angle. The flex gives a couple of degrees of bend which helps it all bolt up nicely. I would rather not have to have the pipes cut, lengthened & rewelded for the sake of saving headaches, because the cat looks like its mounted slightly further back than stock, which the welded in flex pipe helps to reach. Kinda hard to explain in words. Crazy japs.
Though if thats what i ultimately have to do, it's almost worth spending the extra and just getting the HPI. Or if theres no gain to be had, back to stock.
Edited by _x_FiReStOrM_x_
https://www.sau.com.au/forums/topic/417304-need-a-dump/#findComment-6697102
At the risk of starting the usual shit flinging contest; why do you consider the split to be better, how much difference in terms of performance is there or is it purely for sound or ground clearance issues?
i got one you can have with a screamer pipe attached if thats your thing :P
Cheers mate, but i need to keep things a tad more inconspicuous due to the cops around here. :P
Looks like there's not too many options in the short dump pipes. Did anybody notice a big gain in performance from fitting just the dump alone? Mine was so long ago i cant remember.
https://www.sau.com.au/forums/topic/417304-need-a-dump/#findComment-6698575
I base it on my knowledge of gas flow (that's what I do) and also some wisdom imparted by a Garrett engineer on PF many many years ago. In fact, so many years ago that it was probably still AutoSpeed forums. Turbine dumps work best when they are not a great big gaping cavity, but are instead a smoothly expanding cone. OK, so that's hard to actually arrange in an engine bay where the dump has to bend downwards pretty well straight away, but teh split dumps come closer to that ideal than big ones do.
Most of the (valid) arguments brought against the split dumps here have centred on the flap fouling. Which is fair enough....the really cheap ones have had a history of doing that. But mine fit fine and has worked splendidly. Boost onset with my RB20 was a lot earlier, and sufficiently more steep that I had to back off the anti-creep in my pneumatic boost controller to stop it from just wheelspinning (which is the basic RB20 characteristic when you have boost wound up and the wastegate held shut.....nothing, nothing nothing, BOOST.) I haven't compared the dump against a stocker on the 25Neo because it didn't make sense to try to fit back the crappy old stuff.
https://www.sau.com.au/forums/topic/417304-need-a-dump/#findComment-6698601
That's really interesting stuff mate, thanks for that! :)
So it sounds like that would be a good way to go, i just need to weigh up whether its worth the $ of having the rest of the exhaust re-tig'd to match up to the front pipe, as opposed to just getting the bolt on HPI for $499. I cant seem to find the just jap full length split on their site though. :s
The only reason i'm going through this is that i need to remove the exhaust manifold to repair a couple of broken studs, so i figured now was as good as time as any to get rid of my china spec boostspikedump lol.
https://www.sau.com.au/forums/topic/417304-need-a-dump/#findComment-6698624
I back to back tested a name brand split with a good bell mouth and the bellmouth outperformed the split by a whisker. I had no issues with fouling of the wastegate. I put down the slight improvement to having a larger area for gas expansion just outside the turbine for the gains observed. Probably the harder you push the car the more the split helps when there are more gases being wasted.
Given that the performance difference was minimal (in my case slightly less with a split) but the price difference is significant why pay more for it?
Either will do the job well enough.
https://www.sau.com.au/forums/topic/417304-need-a-dump/#findComment-6698648
Well this makes things harder lol.. J/k. Cheers Wolverine. The main problem i have is boost control is finicky at best compared to the stock dump. I wonder if my problem is that the w/g flap IS fouling on the dump.. doubt i would have checked that ages ago. You didn't happed to compare either aftermarket one to the stock pipe at all?
https://www.sau.com.au/forums/topic/417304-need-a-dump/#findComment-6698666
True. I will have the turbo off of the car during the process (exh mani has to come off) so i guess i can d/c the actuator and work the flap by hand for test fitting purposes. Still considering trying the stock one again too. Otherwise when i finally get pissed off enough, i'll throw the towel in and get a new complete turbo back system lol.
https://www.sau.com.au/forums/topic/417304-need-a-dump/#findComment-6698801
That... can be arranged. :P
Won't bother with the stocker then, it can be used as a toilet. I think i'll just pull the car apart and suss it out (see if w/g flap is fouling) before making the decision. Was hoping there was an easier solution but no such luck.
Thanks for the help guys. Muchly appreciated.
https://www.sau.com.au/forums/topic/417304-need-a-dump/#findComment-6698884
I was in this situation (had a 'full' exhaust made which didnt have a dump in it...??) and ended up giving up and getting the HPI pipe.
Its nice and shiny, and for the most part it was less stressful. I'm just a lay person but when I held the stock one side by side with the HPI one it was pretty clear one would flow better than the other :P
https://www.sau.com.au/forums/topic/417304-need-a-dump/#findComment-6700538
I did get it from Just Jap due to impatience lol. I didn't actually FIND anything that was a stock dump replacement anywhere else, but my google fu is weak and I just wanted something I would know would fit. I'd much rather spend the extra $ for peace of mind, I didnt get a one piece front/dump simply because the guy didnt have a standard nissan turbo flange.
He didnt tell me this mind you :P Wasnt really the optimal way to go about getting a turbo back exhaust!
https://www.sau.com.au/forums/topic/417304-need-a-dump/#findComment-6701539
    • I can ship Nismo floor mats to you: https://www.oemsoko.co.jp/products/nismo-floor-mats-for-skyline-r33-bcnr33-stagea-wgnc34?_pos=1&_sid=9278c1467&_ss=r
    • Here's the link: https://www.amayama.com/en/genuine-catalogs/epc/nissan-japan/stagea/wgnc34/6642/misc/G49?frame_no=WGNC34-137122 What you think about it? The same product i found on nengun: https://www.nengun.com/oem/parts/40567/MiPwn5qAMfCfmpxHNDnwn5q9MDAx8J-QiW9sZC1qcC0xMTAtRzQ5LS0wMDE/Floor+Carpet+%2F+Mat+2/0688339eba149c19 Bot i have spoken to 😅 ensured me, that mats are 100% original, oem product. I have my doubts. I also heard what you mentioned, that nengun often offers items that are actual not available... On the other hand mats i found on japanese yahoo or ebay are in poor condition and still quite expensive so i'd rather wait for some better offers. My location - Poland. We literaly don't have ANY market for used Stagea parts so need to search outside Europe.
    • You can’t see much on the other side as the lcd is there I don’t think it’s the same as the m33 beside it as the markings on top is not the same was hoping someone had a good quality photo or if they just happened to have the unit in hand, quickly take the cover off and take a photo to clearly show the marking on top to identify the diode   the unit is currently with an electronics repair shop so I can’t take another photo at the moment hopefully they are smart enough to know if it’s a zener diode or not
    • I'd be very surprised if you can buy new OEM mats. But if you can, I want some too!  Do you have links to the variations you found? Also, where are you located? I found that Nengun is happy to list items to purchase but when you do buy them you'll get an email that it's actually discontinued. As far as I know the variations in floor mats are different colour schemes as well as automatic and manual having a slightly different shape. The automatic ones fit into a manual car without issues, but I think you'd have trouble fitting the other way around. I have photos that show the shape difference if you care. FWIW I bought sets of used floor mats in decent condition at yahoo auctions.
    • Hi 🙋‍♂️. Just bought my Unicorn but the interior need some minor work so it would match my expectations ;). I noticed it is hard to get used oem floor mats in good condition so i started to dig if there's any chance to buy set of new ones. I found two websites - nengun and amayama and it looks like one can still buy factory new floor mats in Japan, but thers a small issue. Some mats (i assume genuine, oem ones) are marked as G4900 and these are "discontinued". The ones you can buy are marked as G4911 but i have no idea if these are also oem, made by other producer or some lower quality replacements that looks entirely different. Can anyone help? 😃  P.s. there is also some strange indication - 0V005, 0V015 and 0V505. Any idea what does it mean? Would appreciate any help with this 🙏
