Anyone Know How To Lock The Aircon To Produce Cold Air Only? (As In Mechanically Or Heater Hoses, Etc?)
Hi everyone,
My blend door servo is still giving me head aches, so instead of trying to sort that out for the 3rd time, I wanted to know if anyone knew how to jimmy the aircon to just produce cold air?
I remember reading on a past thread that someone managed to do so by taking out a heater hose or something in the engine bay or possibly re-directing one to just allow cold air to flow? (can't find the thread anymore :( )
Anyway, if anyone knows anything about how to do it or know's a link of how to do so, that's be great as i'm tired of hot air right now lol
thanks
meta
Looping or blocking the heater hoses off may produce cool air, but may produce ambient air temperatures
if your already playing with the blend door, cant you just zip tie it in the cold only position or something? That is the easiest thing to do.
Lol, i've actually zip tied the blend door to cold already, but i'm still get warm air
Pop the cable off the water valve and keep it in the closed position
thanks mate, and i hate to sound like noob, but where is that located lol... i'm just being wary to tread carefully, i've had enough mishaps lately lol
Removing heater hoses wil give judt cold air. Did it on my r33, seems a/c mixes hot/cold to regulate temp so just cold will give exactly that.
Is that cold as in "Cold" aircon? or just ambient cold air?
If you've got the flap locked to cold only, then the reason you are only getting ambient air is that your aircon may be low on gas. when you turn the aircon on, can you hear the compressor kick in? Is the aircon properly cold when the engine is cold but gets warm once the engine does? if the compressor doesn't kick in then its probably low on gas. If the aircon starts off properly cold then heats up then its the heater tap.
the aircon was recently serviced and also re-gassed, so i'm assuming it's not that
The compressor does engaged and works fine, what i'm finding is that once the aircon is on, it just blows ambient air, which rises stays at a constant warm heat.
It was working perfectly fine prior to my blend door servo motor dying
I had an airconditioning place remove the motor and "apparently lock it" in the cold position, which doesn't seem to be the case :(
as for the heater tap? sorry, you may have to explain this one too me sorry lol, not good with aircon
If you have zip tied it so the blend door is in the full cold position and ur not getting cold air then you have a problem. Are you sure its in the fully cold position?
And yeah see if your AC compressor clutch is engaging. Should be able to see the front of the compressor stationary then start spinning when the AC button is pressed on
the heater tap is to do with the coolant entering the heater unit. basically, when you turn on the heater, the tap opens and allows the warm coolant to enter the heater core. if the tap is dodgey then you will have coolant circulating through the core all the time, but this shouldn't affect the air temp too much unless the flap wasn't fully set to cold.
I was under the assumption that it was, however, since i haven't had the time to pull it out, i've decided to just take it to another airconditioning place to sort it out
As for the AC clutch, it does engage, the whole system is working fine, just not producing cold air lol
thanks for the reply mate, I'm having it checked out today, so i'll repost when (hopefully), it gets fixed, hopefully this post will help someone later in the track
Just had it checked, it was the air compressor :(
Now does, anyone know where i can find brand new air compressors for an r32 gtr? and if they're exactly the same as the normal r32 gts-t?
    • The fab work can be as simple as a couple of silicon hoses and clamps to the factory piping.
    • Just sounds like either way you need to do some fab work to get everything to fit, so why limit yourself at that point? If the GCG high flow option is zero effort in and out swap though I'd probably do that. It's almost certainly lowest risk, lowest cost, etc. The HKS GTIII-RS option that Kapr mentioned is laughably expensive for what it is, they charge the exact same for two turbos on the RB26 so their margins are off the charts on that thing.
    • Intake manifold is not a part of the issue. The turbo bolts to the exhaust manifold. That is easy. But close your eyes and picture the physical situation. That is a T3 flange on the manifold and a T3 flange on the turbo. As long as any new turbo has a T3 flange on the exhaust housing, that exhaust housing will bolt to the exhaust manifold. This places the exhaust housing in the same place as the stock one. But now move your mental attention a little further forward. The location of the compressor housing is set by the length of the turbo's core. The stock turbo had a long core. Let's say that it is..... 100mm long. So that would place the compressor housing 100mm forward of the exhaust housing. But a highflow, might well have a centre core that is shorter. Let's say that it is only 70mm long. Now the compressor housing will be 30mm further back in the engine bay than the stock one. This DOES move the turbo's compressor outlet backwards. It also moves the compressor's inlet backwards. You will very likely have to do some work to both the inlet and outlet piping to make everything connect again. I am not say this to make it out to be a bigger deal than it is. I am just pointing out that "bolt on" is sometimes not quite bolt on. The highflow from GCG that Murray linked above (https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html ) uses a core that is the same length as the stock core, and so does not require this extra work. It will look very much like the stock turbo. No-one uses GTR turbos of any flavour (stock, or aftermarket) in a single turbo application on RB20/25. It's not a thing. Yes, people have been putting on GT3076, GTX3076 (and bigger and smaller versions of those) and G30s (of various sizes) onto RB20/25 since forever. But these are not "bolt on". Everything except the 4 bolts to the exhaust manifold change with these. And genuine Garretts are expensive. Non-gen, like Pulsar, etc, are cheaper, variously as good or nearly as good. But still not bolt on. No-one in the right mind would pay for an HKS turbo. Not in this modern day and age. Well, yes, the GCG highflow. You could ask HG what he can do to make the compressor housing sit in the original location. There are surely others doing highflows around the world. And some of the eBay/Temu ones (as reported by Dose) work and don't die. Bit of a lottery though. I would send your turbo to GCG (here in Oz) to be highflowed if you want a trivial no-extra-work option. But seriously, the work required to change inlet and outlet piping is not that hard. That's a boost control problem, not a turbo problem.
    • Thank you all for the replys 🙂 I know that intake would be different but that is one pipe at it is not that hard to get(custom one). I meant mainly bolt to the stock manifold and the turbo elbow. I looked and many sites/forums but they are just "old" with some old HKS turbos from GT-R i guess? What about some Garrets?  Or any other turbo? Is there even a turbo which i can just bolt on? 😄 And yeah i know about that new HKS but that is like 2000k USD without taxes/shipping in here   Iam getting a touch up tune but my "problem" is that on the "not" hot day iam getting peaks around 0,9 bar...and when it was around 15 Celsious i saw peak around 1 bar which is just too much for stock turbo. And of course turbo is old and i like to get some new one for a piece of mind 🙂
    • I'm working on the assumption that our friend Jasmine here is a Russian (or, possibly Ukrainian) spammer/spambot, based purely on the number of such that I have been having to neuter in the last few weeks. IP address for the OP above was in WA. But that could have been via VPN. Posting at quarter to 4 in the morning is a good sign of being from somewhere in Europe. The last Jasmine that I kicked in the cooch was IP addressed in Ukraine. Even that could have been via VPN, and the bitchbot could have been from Russia, Serbia, China or anywhere. Regardless, was a spambot, so I killed it with fire. The fact that our new friend Jasmine here did not respond in any way to my tart query strongly suggests to me that this OP was just the establishment phase of a user able to be activated for spamming in a week, or 3 or 10.
