  • Replies 52
Sold so far
Ashtray
Rad support mounts
Prices on the main things of what i have available
Rb25de neo complete engine 100ks $1000
Smoked Tail lights $250 pair
Rear bar (no reverse lights) $200
Bootlid $200
Complete doors minus door trims/side mirrors $200 each
Door trims $100 pair
Diff $200
Side Mirrors $200 pair
Side skirts $100 pair (1 has crack)
Front seats $200
Rear seats $100
Lhs headlight $100
LHS headlight loom $20
Lhs guard $100
Carpet $50
Parcel shelf $100
Center console (hinge no good) $50
Glovebox $50
Overflow bottle $20
Interior/boot trims from $20
Fuel flap $50
Interior light $20
Rear view mirror $20
Auto cluster 1xxxxx $80
Aircon vents $20
Sun visors $20 pair
Fuse box cover $20
Climate control $20 missing 1 button
Stereo surround bracket $20
Seat belts $100 the lot or $50 each
Odd parts from $20
Edited by Johnie
Sold so far
Ashtray
Rad support mounts
Reverse lights
Center aircon vent
Rb25de neo complete engine with ecu, auto 100ks loom is damaged $1000
Bootlid $200
Diff $200
Front seats $200
Rear seats $100
Lhs headlight $100
Lhs guard $100
Carpet $50
Parcel shelf $100
Glovebox $50
Overflow bottle $20
Fuel flap $50
Interior light $20
Sun visors $20 pair
Fuse box cover $20
Airbox snorkel $50
Bottom half of the airbox $50
Odd parts from $20
Edited by Johnie
right hand door handle? pick up only live down the road
Sorry not separating from door, will be selling complete
got rhs front splash guard?
Yes i do, however its currently stuck with the wheel. $20 if i can manage to get it off.
darn, how about left side door window motor?
darn, how about left side door window motor? also the two rear rims?
Sorry guys selling the door complete $200 each
No wheels available
hey you got cat back exhaust?
No cat back exhaust available at the moment :(
Bump,
2.5/3inch Nismo catback exhaust will be available for $500 once removed from the car, just cant seem to remove the tight bolts atm
Front and rear seats $300 perfect condition
Smoked tailights $250
Edited by Johnie
R34 non turbo neo cover $50
R34/R33 Stock muffler $50
R34 glovebox $50
R34 2.5-3inch nismo catback $500
R34 airbox snockel $50
R34 LHS Xenon Headlight broken brackets $150
R34 Center console $50
R34 Steering column $50
R34 Climate control/headunit bracket $50
R34 middle console thingy on the top right of photo $50
Edited by Johnie
Engine, loom and ecu??
Yes it still available,, cannot be shown running however its a complete engine
Minus afm, air intake and pod filter as they were damaged
Asking price is $1000 negotiable after inspection
Will go cheaper if buyer can remove the engine as i will need to call my mate to get his help to remove the engine using his engine crane and tools, oh and his grinding skills to cut off the damaged rad support and its currently very close to the engine.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
