  • Replies 52
Sold so far
Ashtray
Rad support mounts
Prices on the main things of what i have available
Rb25de neo complete engine 100ks $1000
Smoked Tail lights $250 pair
Rear bar (no reverse lights) $200
Bootlid $200
Complete doors minus door trims/side mirrors $200 each
Door trims $100 pair
Diff $200
Side Mirrors $200 pair
Side skirts $100 pair (1 has crack)
Front seats $200
Rear seats $100
Lhs headlight $100
LHS headlight loom $20
Lhs guard $100
Carpet $50
Parcel shelf $100
Center console (hinge no good) $50
Glovebox $50
Overflow bottle $20
Interior/boot trims from $20
Fuel flap $50
Interior light $20
Rear view mirror $20
Auto cluster 1xxxxx $80
Aircon vents $20
Sun visors $20 pair
Fuse box cover $20
Climate control $20 missing 1 button
Stereo surround bracket $20
Seat belts $100 the lot or $50 each
Odd parts from $20
Edited by Johnie
Sold so far
Ashtray
Rad support mounts
Reverse lights
Center aircon vent
Rb25de neo complete engine with ecu, auto 100ks loom is damaged $1000
Bootlid $200
Diff $200
Front seats $200
Rear seats $100
Lhs headlight $100
Lhs guard $100
Carpet $50
Parcel shelf $100
Glovebox $50
Overflow bottle $20
Fuel flap $50
Interior light $20
Sun visors $20 pair
Fuse box cover $20
Airbox snorkel $50
Bottom half of the airbox $50
Odd parts from $20
Edited by Johnie
right hand door handle? pick up only live down the road
Sorry not separating from door, will be selling complete
got rhs front splash guard?
Yes i do, however its currently stuck with the wheel. $20 if i can manage to get it off.
darn, how about left side door window motor?
darn, how about left side door window motor? also the two rear rims?
Sorry guys selling the door complete $200 each
No wheels available
hey you got cat back exhaust?
No cat back exhaust available at the moment :(
Bump,
2.5/3inch Nismo catback exhaust will be available for $500 once removed from the car, just cant seem to remove the tight bolts atm
Front and rear seats $300 perfect condition
Smoked tailights $250
Edited by Johnie
R34 non turbo neo cover $50
R34/R33 Stock muffler $50
R34 glovebox $50
R34 2.5-3inch nismo catback $500
R34 airbox snockel $50
R34 LHS Xenon Headlight broken brackets $150
R34 Center console $50
R34 Steering column $50
R34 Climate control/headunit bracket $50
R34 middle console thingy on the top right of photo $50
Edited by Johnie
Engine, loom and ecu??
Yes it still available,, cannot be shown running however its a complete engine
Minus afm, air intake and pod filter as they were damaged
Asking price is $1000 negotiable after inspection
Will go cheaper if buyer can remove the engine as i will need to call my mate to get his help to remove the engine using his engine crane and tools, oh and his grinding skills to cut off the damaged rad support and its currently very close to the engine.
    • The fab work can be as simple as a couple of silicon hoses and clamps to the factory piping.
    • Just sounds like either way you need to do some fab work to get everything to fit, so why limit yourself at that point? If the GCG high flow option is zero effort in and out swap though I'd probably do that. It's almost certainly lowest risk, lowest cost, etc. The HKS GTIII-RS option that Kapr mentioned is laughably expensive for what it is, they charge the exact same for two turbos on the RB26 so their margins are off the charts on that thing.
    • Intake manifold is not a part of the issue. The turbo bolts to the exhaust manifold. That is easy. But close your eyes and picture the physical situation. That is a T3 flange on the manifold and a T3 flange on the turbo. As long as any new turbo has a T3 flange on the exhaust housing, that exhaust housing will bolt to the exhaust manifold. This places the exhaust housing in the same place as the stock one. But now move your mental attention a little further forward. The location of the compressor housing is set by the length of the turbo's core. The stock turbo had a long core. Let's say that it is..... 100mm long. So that would place the compressor housing 100mm forward of the exhaust housing. But a highflow, might well have a centre core that is shorter. Let's say that it is only 70mm long. Now the compressor housing will be 30mm further back in the engine bay than the stock one. This DOES move the turbo's compressor outlet backwards. It also moves the compressor's inlet backwards. You will very likely have to do some work to both the inlet and outlet piping to make everything connect again. I am not say this to make it out to be a bigger deal than it is. I am just pointing out that "bolt on" is sometimes not quite bolt on. The highflow from GCG that Murray linked above (https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html ) uses a core that is the same length as the stock core, and so does not require this extra work. It will look very much like the stock turbo. No-one uses GTR turbos of any flavour (stock, or aftermarket) in a single turbo application on RB20/25. It's not a thing. Yes, people have been putting on GT3076, GTX3076 (and bigger and smaller versions of those) and G30s (of various sizes) onto RB20/25 since forever. But these are not "bolt on". Everything except the 4 bolts to the exhaust manifold change with these. And genuine Garretts are expensive. Non-gen, like Pulsar, etc, are cheaper, variously as good or nearly as good. But still not bolt on. No-one in the right mind would pay for an HKS turbo. Not in this modern day and age. Well, yes, the GCG highflow. You could ask HG what he can do to make the compressor housing sit in the original location. There are surely others doing highflows around the world. And some of the eBay/Temu ones (as reported by Dose) work and don't die. Bit of a lottery though. I would send your turbo to GCG (here in Oz) to be highflowed if you want a trivial no-extra-work option. But seriously, the work required to change inlet and outlet piping is not that hard. That's a boost control problem, not a turbo problem.
    • Thank you all for the replys 🙂 I know that intake would be different but that is one pipe at it is not that hard to get(custom one). I meant mainly bolt to the stock manifold and the turbo elbow. I looked and many sites/forums but they are just "old" with some old HKS turbos from GT-R i guess? What about some Garrets?  Or any other turbo? Is there even a turbo which i can just bolt on? 😄 And yeah i know about that new HKS but that is like 2000k USD without taxes/shipping in here   Iam getting a touch up tune but my "problem" is that on the "not" hot day iam getting peaks around 0,9 bar...and when it was around 15 Celsious i saw peak around 1 bar which is just too much for stock turbo. And of course turbo is old and i like to get some new one for a piece of mind 🙂
    • I'm working on the assumption that our friend Jasmine here is a Russian (or, possibly Ukrainian) spammer/spambot, based purely on the number of such that I have been having to neuter in the last few weeks. IP address for the OP above was in WA. But that could have been via VPN. Posting at quarter to 4 in the morning is a good sign of being from somewhere in Europe. The last Jasmine that I kicked in the cooch was IP addressed in Ukraine. Even that could have been via VPN, and the bitchbot could have been from Russia, Serbia, China or anywhere. Regardless, was a spambot, so I killed it with fire. The fact that our new friend Jasmine here did not respond in any way to my tart query strongly suggests to me that this OP was just the establishment phase of a user able to be activated for spamming in a week, or 3 or 10.
