That was my pick, I was too worried to head down that path when Link NZ refused to help with setting up the camshaft signals. The frequencies are much different to the 350z due to the electronic actuation, meaning a VQ35 map may cause piston damage on the VQ25det. As Trent recently managed to adjust the output frequencies for an rb26 Vcam install, I am confident the link can do it, but this car will be the first.
Anyway, I am interested to help out if it's required and I will probably be heading down this path myself very soon, I already have the information they will need. (Oscilloscope captures, frequencies etc)
I hope it all goes to plan for you guys. :)
Yep, HP.
Looks more responsive than a normal 3076R, will be interesting to see how far you can push it with more boost and revs!
How much boost you planning on running, 3bar seems to be the new benchmark :yes:
Wow that things gunna be potent when it starts seeing more boost! :woot:
Good luck mate looking forward to seeing how much grunt this things gunna make :thumbsup:
Good thing its the same compressor on the FP Red!
Run in didn't happen. I had a fuel pump fail on the dyno so missed out on track day.
Car is back at Brad's being finished off (Risking - Pro Fab). Next dyno run should be in a few days then off to the Wakefield 300 totally untried and untested for some fun.
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
