yeah that is completely wrong
it should never be like that
if you unplug the AFM sensor completely does it do the same thing?
if you unplug the TPS sensor completely does it do the same thing?
when you unplug the sensor on a car thats running a PFC the sensor name will go in black highlight under ETC, SENSOR SW CHECK and the engine light will come on
this might give away which of the sensors wires is mangled up
if you unplug the AFM at the sensor and it still shows a value you know the AFM wires are f**ked
if you unplug the TPS sensor and the values go away you know the TPS is at least wired in properly, but could still be bridged at the loom etc
Thanks for the info I will try that later. I do know that I can completely have the MAF disconnected and the same voltage phenomenon occurs. However if the MAF is not plugged in the car won't start and run its a strange scene to be sure. It seems the MAF is still giving a reading but it is also reading from the TPS as well hence the weird voltage fun. Since I have wired the MAF directly into the PFC with my own wire that leads me to believe that the PFC is the culprit however I will do some further troubleshooting with your advice such as unplugging TPS etc. I will keep you posted on what I find.
Edited by debusan
  • 4 years later...
Any resolution to this?
I am having the exact same issue on my 34 Gtt with power fc.
Car was warming up and died.
will crank twice, fire, then die a second later.
Motor has 160-165 across all 6.
New gs342 Walbro's are running fine
Unplugged afm, still reads same value as tps.
unplugged tps, no value registers
Tomei plug will only go on 1 way, all soldered joints good.
Loom not melted/ no rub throughs/ all behind heat shield.
Ecu connector looks ok. No pinched wires, terminals seated in connector. Nothing stands out,
Found a shit ground in engine bay near turbo, Ran a test piece to ground motor to strut tower. Same result.
z32 and Tomei plug is 500km old
tune by Jez on power fc is only 500km old.
really hoping I don't have to fork out for a new Ecu.
For anyone with an issue like this in future. Been talking to fc hako re a possible repair to the ecu, he suggested I pop open the afm to check for dry joints in the pins at main connector. Joints were good but four this, brand new afm from justjap also.
1 circuit not soldered and the Blob of solder intended for bare joint bridging 2 circuits, unpicked with finger nail, no penetration to solder on other circuits but enough to bridge them.
First thoughts would be it should have fizzed at first power up before I even hit the dyno, but it's possible the blob dis lodged and rolled to its final spot.
New z32 tomoz, will power up and see if ecu will work per normal
    • I take it that you bought the centre to suit the GTR axles? As in there was a plan, not just somehow lucky that it worked? It all looks excellent, by the way.
    • New engine block time. Up to you whether you want to keep going down this road with this project. Unfortunately a lot of these cars are like this. The road to getting these cars into decent shape is long and not fun for reasons that you're discovering.
    • Essay time. First things first, an RB running stock turbo and boost levels shouldn't get so bad as to stall from reversion if the recirc valve has been deleted. Should get a little fluffy and annoying, but in my experience, not so bad as to stall. Of course, every car is a bit different, so it remains possible that stalling will happen. So, running with no recirc valve is somewhat of an option, for otherwise stock stuff. Atmo BOVs cause all sorts of shit, even on an otherwise stock setup. Only gets worse the higher the boost and the bigger the turbo. At that point you really need to go for a different ECU and no AFM. Rebuilding the stock recirc valve configuration is not hard. You just need a stock or aftermarket BOV with the appropriate adapter for the 2 bolt flange on the back of the J pipe, and to get/make an appropriate ~1" pipe to get the air back to the turbo inlet, and to possibly modify the inlet (if it is not stock) to take the recirc pipe back in. Not hard. Just takes some cutting and welding. Putting an R35 type AFM into the car anywhere is not as simple as just buying the AFM and throwing it in. You will also need to buy the appropriate boss that will then need to be welded onto the pipe where you're installing it. You can clearly see why by looking at the photo posted above. They are not a "simple" swap for a stocker. You can't put on in place of the stock AFM. You can put one in place of the stock AFM, if you get the mounting boss and weld it to some pipe and otherwise make that pipe piece work like the stock AFM housing. Or you can buy such an adapter, either complete with the 4 bolt flange for the air box, or without, for varying degrees of work needed to then make it fit your stock airbox or some pod filter or whatever you have going on. Oh, and the R35 AFM is not plug and play. The wiring is different, but changing that is trivial. The plug is also different so you either end up repinning the original wires onto the new plug, or you just use a short adapter. If you weld a boss to the cold side pipe, the cold side pipe really wants to be 3", otherwise the scaling on the meter can get a bit weird, but whatever the pipe size, it's not as easy as just using the (fully documented in the Nistune doco) simple method for choosing R35 AFM in X" pipe size in the software, because the scaling will already be a bit different. Anyway, all of this has been comprehensively worked through on the Nistune forums, so there is full knowledge available. I would use a Link/Haltech before I would bother putting an AFM into a cold side pipe. That's a lot of effort for a bodge. Nistune is great, can work well even at fairly high power levels, but you are stuck with the limitations of it being the stock ECU, which includes needing to use an AFM, which is not always convenient for every set of modifications. You have to have a think about what you already have, what you want to have, and decide early if you'd be better off jumping ship to an aftermarket ECU. This so you don't waste time and money doing things 2 or 3 times. Never heard of ECUmaster. Sounds like a backyard operation. If there are good tuners for it where you are, and it is a solid product, then it will be fine. We're only talking about an R engine here. Back in the day they all ran on crude nasty early 90s ECUs and they were fine. You don't need a rocket surgeon's ECU to run one.
    • So left off with high hopes of having a gearbox in pretty quickly........ Got the adapter plate that week and had to chase a few threads and work out how/where everything goes as no instructions. Got the adapter fitted, test fitted gearbox and found had to cut and shave a few things. Tunnel required some hits with a decent hammer to give some clearance on passenger side but it fits with no problems,  could fit a 8hp70 with a little more work. For a cross member I wasn't going to spend $1100 on so shiny machined piece. Went through a few designs and remembered I had a gktech s chassis to cd00# cross member. Fitted that and found its close enough with a few extra bits welded so have gone that way and still a work in progress.  After this got into modifying the intercooler with some bends and clamps. I was procrastinating on this as was not keen to cut up and weld it myself but happy with the outcome.  Onto the radiator shroud and oil cooler mount. This thing took way longer than I thought it would but having to add an extra oil cooler for the trans and wanting everything within the chassis rails its good enough for now. It mounts to the chassis and gives plenty of room for lines and pipes. All the coolers are rubber mounted and sealed the shroud on the top and sides, will use some tape to seal the bottom gap of about 10mm. 20250508_111500.mp4   Next job was to build the new diff and after a delay with a friend got built this week. I ended up putting it all together with supervision and was good to learn how to set one up correctly. I ended up going a 3.69 ratio, nismo 1.5 way gt pro with gtr Axel's. Stripped it all down, gave all the parts a good clean, pressed on new bearings and set backlash. Was good working in a clean assembly room with all the gear. Once got home wire wheeled the case and hit it with some rollbar/chassis black paint. Got a few more bits done but will leave them for the next update.
    • That could be drilled, ground and welded. Would stop it progressing and leaking. But that block shouldn't be pushed very hard, as what you see there is a massive warning sign. But that fix also isn't going to happen properly with the engine in the car, and assembled. So you're looking at anew block if you're doing all that work anyway.
