Ok so I'm kinda fond of the Idlers style big lettering on the side of the tyres. What's the best way to achieve this?
I'm assuming a lot of these are stencil + rattle can jobs but surely there are other ways? Is there anyone in Oz doing something similar to http://www.tirestickers.com/ ?
Here's what I'm after (via Speedhunters):
RWB Idlers style:
Interesting idea. I'd want to know how well paint can paint lasts with the heat/cold/twisting a tyre has?
Hopefully it'd be better then those white walls people get painted on as they don't last
Well that's the problem, from what I've read basic brush + normal paint job just won't last. Some people have to repaint theirs every couple of months.
The stencil + spray idea seems easiest as it's very quick to redo. However, I can imagine it starting to look a bit messy around the edges after a few times.
Has anyone got first hand experience with stickers/decals? How well do they last?
In 1970, I used to pinch my younger sister's oil based crayons (white or yellow) and it was like 'colouring-in' hehe...
I forget, but it might have lasted a couple of months I think > Kleber tyres never looked so cool lol.
  • 1 year later...
Ok so I finally got around to trying this the other night, with some Goodyear Eagle stencils from Canada: http://www.racelinedigital.com/store/index.php?main_page=product_info&products_id=2048
The bad news is, acrylic paint definitely does not work, it's already flaking off after a couple of days...
The other bad news is, I found out that my tyres are shagged when putting them back on the car after doing this :(
The good news, I really like the look:
Any ideas on how to do this properly and which paint to use?
(I'd also love to 3D print some sidewall shaped stencils to avoid buying more sticker ones each time this needs to be redone...)
I have spent quite a lot of time trying various paint and pens and my conclusion is that it is possibly highly dependant on the tyre wall stiffness.
I use a regular pen type on a set of Falken RT615 and it lasted for 1000's of Km.
Now with a set of Bridgestone RE002 and even two different tyre wall specific paint cracked and peeled within a few 100 Km.
I just use some stuff I got from ebay for like $6 it looks like a paint touch up brush/pot that you get from supercheap or so but it ends up drying kind of rubbery, last for agesss unless you get up and close to it with a high pressure gernie lol... just like any type of paint job make sure the tyre is clean before you do so eg. tyre shine and that sorta crap, I just wipe over the lettering with some wax and grease remover quick sand with some 320 then apply.
Thanks guys. I'd really prefer spray paint if possible - the stencils never stick on 100% so a brush/pen is likely bleed under the edges (the spray does a bit, too).
But then again that's if you just want to do the raised lettering that's already on the tyres.
Yeah nah, the lettering on the tyres is tiny. I want to go big :)
Mad Mike recommends 'fast dry enamel or primer' in the Tire Bomb post on Speedhunters, might give those a go.
I'm considering getting a custom made laser cut stencil made out of plywood or perspex, would allow me to respray easily when needed...
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
