Ahhh, memories of when I had a car with some balls, was running 380kw on UNIGROUP dyno at the time,GTS-T, 25/30, manual, on old drag radials, my best ever was 11.009, but I had a lower MPH, I did run a 134mph, once, on the same day, lost the slip so......"if no slip, it didn't happen".
Latest car would probably take twice as long and have half the MPH, oh well.
More time slips needed.
the silver one by any chance? built by Advan initially?
Initially Advan did "some" work on it, after a year the diff was the only thing remaining from it's time at Advan, UNIGROUP rebuilt the engine and replaced,  um, everything except the diff
I saw it at roll racing a few months ago, rebuilt again and running a slush box, it was funny, the boy said "there's your old car" as it went by.
Had a look at it in the pits, alot more work has been done since I owned it
On 8/15/2018 at 1:19 PM, Taha said:
140 mph    has a 9 for sure
gearbox makes big difference
very difficult with a syncro 6 speed however mate with dog engagement 5 speeds has run 9.7 @ 142 mph
i ran 10.4 @ 140.68 with 1.5 60 ft.
need to get back out there once my boost control is sorted
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
