If you are going to go to the expense and hassle of doing an engine swap you should really consider something that is going to give a significant performance increase as the RB20 NA to RB25 NA isn't much of an improvement. Have a chat to Nick, he is a good bloke and is going through an LS1 conversion at the moment. Nick is pretty easy to track down, he only has one leg, a special arm attachment for his ratchet shifter and captains the fair ship Natro. Here is an artists impression:
Bahaha, thanks bro... Loving the artists impression :thumbsup:
Going from a 20e to the 25de you'll deffinetly notice a difference, but... It still won't be a rocket ship, but it will have alot more "go" refer to the "Are Natro Rbs really that slow" thread.
My conversion is a lot more difficult then what a turbo rb swap would be into the r chassis you have. So like i said before go and have a read through the "how to turbo your NA" thread or track down a turbo rb donk, either way you'll need an engineers mod plate and have to alter your rego/insurance details :)
Edited by Captain Natro
Sorry mate thought this was another thread ive posted in that was similar, to cut a long story short.
You've unfortunately found yourself with possibly the worst skyline combo you can buy :(
question number 1... Are you on your Ps? If the answer is yes then scrap the whole thing as you'll require a mod plate instantly disqualifying you from legally driving it (regardless if its NA or not)
So you can't do any of the work yourself, this is a major disadvantage as a work shop is going to charge you $70 an hour just in labour alone before they ad parts on top of that.
....have a search around the place on here regarding (Natro) engine conversions I'm sure you'll find something.
(I have a feeling you'll be shocked by how much this will end up costing you if you went down this original route)
Rb20e to det swap: http://www.skylinesaustralia.com/forums/topic/418058-rb20e-to-rb20de/page__pid__6721237#entry6721237
Na+t conversion thread: http://www.skylinesaustralia.com/forums/topic/249186-nat-power-results-na-t-turbo-conversions-only/page__pid__6587345__st__140#entry6587345
Are they slow? (first few pages are relevant, the rest is rubbish, partially my fault lol) http://www.skylinesaustralia.com/forums/topic/417003-are-nas-really-that-slow-or-are-people-talking-out-their-ass/page__pid__6722430__st__320#entry6722430
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
