Hi all selling some more gear to help fund a new half cut for the GTR
1) Defi BF Series Amber illumination Boost, Oil Temp and Water Temp gauges. Comes complete with all wiring and also Defi controller.. Wiring is as new and not chopped and changed etc. All sensors of course and will throw in a Greddy Dual A pillar pod gauge holder to suit R33 (GTR/GTST)
Looking for quick sale so $400 + Freight
2) OEM BCNR33 fuel rail complete with fuel reg has Siemens 750cc injectors installed
$300 delivered anywhere in Aus
3) RB26 "Twin Turbo" pipe I have two available one has no twin turbo badge.
Complete pipe $80
Incomplete pipe $40 + Freight
4) RB26 Modified RWD sump complete with oil pick up and baffles (standard) Note this is not an extended sump simply modified to suit RWD application.
$100 + Freight
Please PM me your email address for pictures as I can email through hi res shots
For any urgent inquiries please txt me on 0429 230488
Cheers Marty
https://www.sau.com.au/forums/topic/418978-surplus-parts-sale/
  • 3 weeks later...
  • 2 months later...
Bump- I bought and paid for the rwd gtr sump on the 12th March and have not yet received it. Can you please get in contact with me.
Alternatively if anyone knows Marty and what his situation is that would be appreciated as he has stopped replying to my text messages.
  • 3 months later...
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
