Still have lots of r32 gtr parts available located in melbourne in Fawkner please call on 0432526472 for details .bonnet very clean no dints gun metal grey $500 front seats driver side has rip passenger very good condition $380 the pair g sensor $220 cluster ith 120 thousand ks $150 dash has no bubbles or rips $200 with air vents fuel pump complete with sendor $100 rear boot with gtr badge $180 no spoiler rear bar $100 diff very good condition $500 front after shocks $150 good condition cooler piping $50 each have lots left airbox$100 doors 150 each or 200 with glass full set of key locks and ingniton and key $200 stocks gauges $70 steering wheel in fair condition $70 drive shafts still have all 4 $100 each front castor rods $70 each ac condessor $100 front clutch fan $80 5 stud conversion with brakes calipers and hubs $600 rear sway bar $100 gear box cross member $70 tail lights $120 the pair seat belt in very good condition $40 each still have lots of parts selling bare shell with a few bits can not complianced $400 please call for pics and il send them threw
https://www.sau.com.au/forums/topic/419026-wrecking-r32-gtr/
  • 4 months later...
