Hi guys,
I just returned from a trip and my battery is dead. So since the keyless entry isn't working, I tried to open the drivers side door manually and there was some sort of cap over the key hole. I grabbed a flat head screw driver and unscrewed the cap and it revealed the key hole, but theres some kind of hood with threads for the cap that I originally removed blocking the key from being pushed in all the way?
Any ideas would be greatly appreciated at this point, Help me out guys!
cold climate car. that needs to be changed to the normal type. as for getting into the car . look at it fron the other side of th car andvwork out what you need to push and how you need to push it.
i can fet the correct lock for you but you ay neec to get it coded to your key by a locksmith.
Hi Luke
The bad news is your car is like mine and has had the drivers side door lock removed and a cover plate inserted.
My car was a cold climate build and while I never had it categorically confirmed by Nissan Japan it would seem to be a modification by the dealer or factory to avoid icing up of the keyhole lock mechanism, or something like that. I have absolutely no idea how they expect you to gain entry with a flat battery, which is why I bought a new lock and pulled the door apart and fitted it so this would not happen to me.
I know this doesn't help you out much with your problem but even though it has been 4 years since I did this job I don't think that the driver's door is openable by just removing the cover plate.
I think you will have to work on releasing the bonnet by raising the car and removing the under body tray and/or front grille to gain access to the bonnet release catch from below. It won't be easy and if that doesn't work you may need to find an external source of wiring to recharge the battery to permit entry. Chris Rogers was very helpful with ideas when I got an extra key for the car in 2008. He might be able to suggest something better. Are you reading this Chris!!!!!!
I have the US 2004 G35 work shop manual if you need anything looked up. They are mirror images of our cars in most respects except some secuity electronics etc.
Good luck!
    • Lets say I wanted to buy this, specifically for this purpose. How do I actually perform the function. Can I still buy a Consult-1? Am I about to be burned by the fact my car is a 2000 model Series 2 R34 and thus will be some stupid other system? Do I just need this -> https://obd2australia.com.au/product/nissan-consult-14-pin-to-usb-ddl-diagnostic-interface-with-ftdi-ft232r-chip/ And with what software?
    • That's probably OK. That's a face to face compression joint between two surfaces with the clamping load provided by those bolts. So.... it's unlikely that the bolts will end up feeling that load in shear, unless the clamping surfaces are not large enough, bolts not got enough tension on them, etc etc to prevent the two faces from moving wrt each other. Which... I would hope the designers have considered, seeing as it's probably one of the most important things the upright has to do apart from resist collapsing in its own right. But yes, it would definitely be worth asking them what their safety factor on that part of the design was. I tend to think that the casting, being a casting, is not necessarily the strongest bit of material in the world. It's about an inch square, and when you think about the loads that are being put into it, you have to wonder what safety factor the Nissan boys (and every other OEM engineer who has designed all the millions of other uprights that look essentially the same) used to account for defective casting, aging, severe impacts on the wheel, etc etc.
    • Those bolts would be orders of magnitude stronger that cast aluminium though.  And its mainly clamping force, not shear they are dealing with?
    • Except all that twisting force that is breaking a cast piece, appears to be going through 4 bolts in the picture Johnny posted of the BryPar one...
    • The smart approach is to use the gearbox loom from the manual car. Makes it a lot easier - just plugs into the switches on the box and plugs into the main loom up near the fusebox. Then you only need to deal with bypassing the inhibit switch. The other approach requires you to use the wiring diagram to identify those wires by colour and location, perhaps even indulging in a little multimeter action to trace them end to end to make sure, and then.... you will have the answers you need. The R34 wiring diagram is available on-line (no, I do not have a link to it myself - I would have to do a search if I wasn't able to go to the copy I have at home).
