  • Replies 192
good job!
however for the comp, you had just a little too much resting hang time on that first attempt at the bottom of the reps. As per the rule.
* No resting at the bottom of the rep,
Your first 2 reps are right in that first video set for form, are what you are after. All the way to the bottom/straight arm stretch. then straight back up ,no hang time.
Resting is way harder, if you want proof, make everyone rest for a count of five at the bottom, see how they go then
From experience it's actually easier to rest in a hang between reps.
As macdog appreciates from his recent experience, a little rest is helpful , There is an opportunity for relaxation of some of the key back muscles at the bottom of the rep.
I can hang for quite some time, almost to the point where I can rest between sets. The muscle fatigue is different, it is mostly your grip and arms. This is a back movement chiefly the way it prescribed.
Agreed, it's like bouncing deadlifts when doing them for reps. You use the elasticity that is stored in the muscle when you don't pause, whereas with the pause you have to generate all the force.
No. You will find done right you are lowering just past the point where the dynamic tension affords much advantage. This 'bouncing' is also noted as 'not allowed' in the rules.
I have no problem if someone believes the rules makes the pullup 'easier'. This belief alone might help you do more.
However, as the rule stands. Pauses are out. If you don't need to pause , don't do it. Then we can count the effort.
+1
If the rule benefits you, then why complain about it??? It's not that hard to stick to it. Get some more vids up people...the weekend is over now!
Plus...
I think doing chin ups first thing in the morning is better.
Punched out 15 this morning at 6:30am no rest. dont have a video though. will take one thursday morning!! haha
    • I was just driving into work and while on my drive, I went to accelerate and noticed the car would sputter/hesitate and I’d hear a few pops from the exhaust before it started going faster. Then I also noticed that when I push my clutch in, the car would die. This all started happening today. Any ideas?
    • That is a lovely Volvo, just saying. Yes I should have got an 260RS when they were cheap. I do regret now.
    • ^ lots of good points made above. The thing is, "aggressive" or "flush" fitment is relative depending on how much you have been influenced by social media. My starting point is always "look at the Nismo RWD specs". That is where you should start, then start measuring as GTSBoy as sort of mentioned, because every car will be slightly different. My 8.5"+35/9.5+38 will not be "flush" enough for you because you want more "pumped" look, which is why you measure. Tyre sizes and brand/models also make a difference. Some tyres are more chunky/square, some are more rounded. That means you could get away with more aggressive offsets without rubbing. But then it also depends on your ride height. Also depends on how much your car copped damage before being shipped from Japan. So it goes back to measuring your car yourself and determining what can work. Those Nismo specs are used bacause it's a safe spec for standard car (suspension. body) with chunky tyres. But then I put 265/35 wide tyres on R34 GT-R wheels, and currently run 285/30 tyres on 18x10 wheels.
    • Sounds pretty awesome. I recommend creating a new build thread and posting all your goodness in there.
