Ok guys I really need your help.
Im sitting here covered in fuel thinking I had a dead/dieing fuel pump. I just spent 200 on a new one, but this didnt fix my problem.
I think my coils have given up the go. What happen is when I started it today I went for a small drive (hitting boost) as you do and it was fine, I was going to the Beenleigh pet store. Next thing I know I put my foot down, not hard but normal and she just bogged down, lost power then came back lost then back all the way down to a roundabout where I turned to head back home.
Stilling at the lights it was running like shit and when you put the pedal down without being in gear it felt like it was running on 1 cylinder and could smell fuel. After I got past the lights and got upto the Pasific hwy after about 80kph it was fine again and didnt play up till I got it home in cornubia, now ive got a darkish small amount of smoke from my exhaust and as she sits right now she isnt liking idle.
Would anyone have some coils they are not useing if possible to see if it is the coils or has anyone had or seen this issue before?
I am a 3rd year Mechanic so I do have some brains but this has me f**ked now. all lines are good?
The only other thing is my coils have been tapped up by the owner before me so I put a small amount of rape tape over it to make sure no spark was getting lost to the side walls
https://www.sau.com.au/forums/topic/419146-r33-help/
boosting on idle means a few issues are going on. firstly it depends on where the boost gauge it is getting it's reading from, as it may simply be an issue with gunk in the boost line resulting in it holding boost in the line. if it reads from the intercooler pipe then it will never see vaccum, but may be seeing positive boost on idle, which means that the timing is WAY out. essentially it has anti-lag going on because the timing is extremely retarded.
if the boost gauge reads from the plenum (stock location), then it should read vaccum at idle (or zero if there is a major leak), but it would be very hard for it to see positive boost at idle as the throttle butterfly is closed and the engine only gets the air it needs to idle from a very small hole in the throttle body, and the IAC and AAC. you would also hear the turbo spooling a bit (depending on intake setup).
https://www.sau.com.au/forums/topic/419146-r33-help/#findComment-6734817
AFM I think is f**ked, only shows 0.08vts on my scan tool that used from work, I'm thinking its f**ked, sadly from my supplier there $580 new or 270+gst for a reco, wreckers at coopers are $250
Anyone know a better place?
https://www.sau.com.au/forums/topic/419146-r33-help/#findComment-6736852
Yeah... right here.... plenty of people upgrade to Z32 AFM's that have perfectly fine standard ones
OR
Do the tutorial for resoldering the joints inside the unit. If you have a soldering iron and some basic skills will cost you next to nothing. Or if you have a mate that is an auto electrician etc then it will cost you maybe a 6 pack :)
https://www.sau.com.au/forums/topic/419146-r33-help/#findComment-6736868
    • To follow up a question from earlier too since I had the front bar off again (fking!) This is what is between the bumper and the drivers side wheel And this is the navigator side, only one thing but its a biggy! So basically....no putting coolers in the wheel arches without a lot of moving other stuff. Assuming I move to properly race prepping this car I'll take that job on and see how the computers respond to removing a whole bunch of ADAS modules
    • So I prepped the car for another track day on Wednesday (will be interesting to see coolant temps post flushing out and the larger reservoir, with a forecast of 3-14 being 20o cooler than last time I took it out). Couple of things to mention; since I am just driving the car and not taking a support vehicle, I took the rear seats out and just loaded the back up Team Trackday style. Look at all that space! To cover off removing the rear seat....it is weird (note the hybrid is probably different because it wouldn't have folding rear seats) Basically, you remove the lower seat base, very similar to a r series but it is a clip that pulls forward to release the base rather than it being bolted down. Easy Then, you need to remove the side section of the rear seat on each side. There is a 14mm head nut at the bottom of the side piece, the it slides upwards off a hook at the top to release; you also need to unhook the seatbelt from the loop at the top. Then the centre piece is weird. You need to release/fold the seats forward with the tab in the boot on each side From there, there are 2,x12mm headed bolts holding the rear of each seat to the folding bracket, under the trim between the rear seat and the boot (4x christmas tree clips there, they suck). The seat is out but you can see where the bolts attach to the bracket
