Hey Lads,
So this saturday I was going to front up with my 33 to Mallala for a practice session, to be honest the only motorsport event I have ever done was a motorkhana .
Can anybody give me some insight as to how Mallala run their track practice sessions ?
Any advice for a novice ?
I am going to do an oil change before I go, taking my air compressor for tyre pressures, wheel brace to keep check of my wheel nuts etc.
The car is being trailered there and home so if I break it I will call it a day rather than try and fix something there.
https://www.sau.com.au/forums/topic/419206-first-track-day-at-mallala/
  • Replies 68
All that so far sounds good, check cooler clamps and maybe grab some spares from repco before hand Hopefully I catch you out there
So your heading out this weekend then Steve ?
gates open at 8:30 from what I read on mallala's website, whether that actually is the case could be another thing ?
I will only be on street tyres etc, I am hoping they can put me a in a slower group (preferably something with honda civics, toyota corolla's, greyhounds or something)
I don't think so. Last time I went to one of these practice days I got there an hour or two late and still got on the track.
Ricky_Bobby, they split everyone into different speed / experience groups. You should just be able to let them know what group you want to be in.
Still have the last few track day sheets in my glove box.... Usually
Group 1 - Open Vehicles (those with no roof literally)
Group 2 - People with CAMS License
Group 3 - People with single day license (if you're new, you'll have this)
Group 4 - Go Karts
Group 2 can mingle with Group 3 if they feel like or have mates with (as long as they have enough wrist bands).
All the checks have been covered above. But in short, oil, water, brakes**, tyres....
Will see you out there! have 4 mates plus others I know all going out (including the old fella)...so should be a good day!
15 minutes between sessions, therefore about an hour each time you go on with your group.
Edit* = mate turned up at lunch last time, still gone on track or afternoon sessions (about 4 sessions from memory).
To be honest on the Mallala track day's I've never seen it...but if they see someone leaking alot of water or oil they'll do something. At the Time-Attack's there is definitely full-inspect scrutineering, but this isn't one of those :)
Remember long sleeve shirt, long pants, sealed shoes.
As others have said, give everything a once over, make sure you've got enough brakes, etc. I wouldn't stress too much about dodger last minute mods like an oil cooler, cos if you spring a leak your day will be over. Just drive to your car. Ya won't be putting too much stress on things running street rubber and pads.
You need wrist to ankle coverage like most events, helmet of course
Mallala run practice days are usually self scruitineered, so you just sign to say it's all ok. I usually rock up by 9, complete documentation (plus a briefing for first timers). Then unload ( I simply empty my boot) then check everything is cool and stand around talking shit till your session starts.
Run at your own pace. You will be in the day licence group which will have a mixed bag of cars and experience, so keep an eye out for the other cars, can be very unpredictable. Each session is 15 minutes and you will be out every hour. After a couple of sessions you will get used to what the others are like and get into a groove.
Be ready to uncover issues you found before such as boost leaks and brake fade. Most importantly have fun !
Will probably see you around
    • That R31 was so cool. Only did Orange Park once. Scared the hell out of me.
    • Selling my TE37SLs since I've switched to smaller wheels.  They're for sale in Japan but it's pretty simple to send them overseas; USA excluded, since JPPost isn't sending there at the moment. Specs Front: 18x9.5j +22 5x114 Rear: 18x10j +20 5x114 Price: 320,000 JPY/ 3,285 AUD (current FX rate) Condition: a few scratches here and there, no bends, distortions or cracks.  Tires will not be included for international buyers, I'll get them dismounted before shipping. They're currently listed on yahoo auction and will be shipped in Japan with the tires if they sell here. Shipping costs to Aus: EMS (1-2 weeks): AUD 1,175 (current FX rate) Sea (2 months): AUD 460  (current FX rate)
    • The alloy coolant reservoir has a sight glass, so as long as I can see coolant in the sight glass it's GTG, as for PS, it isn't anything catastrophic if it gets low, and as it hasn't lost a drop since I have owned the car I cannot see it being an issue, even after putting the "big block" 2.5 in....LOL The only time it gets slightly messy is at oil changes, as the oil filter sits above the frame, and I need to use a plastic bottle with its bottom cut off to catch the flow when loosening the filter
    • Good on you for taking on the job, but it is a big one. Even if you have bolt on manifold and turbo, you will need: Post throttle pressure source to boost controller to wastegate (and FPR, and ECU/MAP sensor) Pre throttle pressure source to top of BOV(s) Oil feed - you can take that from the standard port in the middle of the block Oil return to block under the turbo - this is much trickier than it seems to route a decent/wide pipe past the manifold. You really can't use rubber hose because it is way too hot there, and also the oil out of the turbo core is a bit frothy so it needs to have a decent diameter Water feed - you can take that from the standard port in the rear of the block. Water return - mine runs to a T into the heater box return, just make sure you don't create a high point making bleeding hard. All of those lines should use 200 series style teflon braided hose with heat shielding because everything needs to be routed past the manifold. Also a turbo beanie is a really good idea to minimise the chance of the car catching fire (under bonnet lining in particular) You also need to decide a cam cover breathing solution as well, will you vent externally via a catch can (probably illegal) or return to the intake (plumbing required and can oil up everything over time) Keep in mind the intake and exhaust piping in the engine bay will be custom so you either need to be able to fab ally and steel or have someone you can get a car that isn't running to. Get the wideband fitting welded into the dump pipe at the same time. Also, just my opinion, a screamer pipe attracts attention and doesn't add power, I'd plumb it back if you want to be allowed to keep the car on the road. BTW do you know anything about how healthy the motor is, and what power you are targeting? Doubling or tripling the factory power on an unknown motor is a little risky. Also fuel system will need some attention (pumps, high current hanger, direct power and earth feed, injectors etc)
    • Wrinkle black will be a thing for both
