As others have said, give everything a once over, make sure you've got enough brakes, etc. I wouldn't stress too much about dodger last minute mods like an oil cooler, cos if you spring a leak your day will be over. Just drive to your car. Ya won't be putting too much stress on things running street rubber and pads. You need wrist to ankle coverage like most events, helmet of course Mallala run practice days are usually self scruitineered, so you just sign to say it's all ok. I usually rock up by 9, complete documentation (plus a briefing for first timers). Then unload ( I simply empty my boot) then check everything is cool and stand around talking shit till your session starts. Run at your own pace. You will be in the day licence group which will have a mixed bag of cars and experience, so keep an eye out for the other cars, can be very unpredictable. Each session is 15 minutes and you will be out every hour. After a couple of sessions you will get used to what the others are like and get into a groove. Be ready to uncover issues you found before such as boost leaks and brake fade. Most importantly have fun ! Will probably see you around
Cool, thats really good insight as to how the day runs and what to expect etc.
Good info from everybody really ! , hopefully I might meet some of you guys out there, I am hoping that they have sheds to rent with power etc ? .
Thinking of brining my toastie maker so I need some volts for that ! .......... maybe my air compressor too I guess ? ;)
I will be the stock looking blue over green R33 , come and say gday !
  • Replies 68
I think given my car isnt heavily modded for power and its all standard braking, it will be a remote chance. Brake fade will get the better of me before I boil the fluid me thinks...
I will get some better pads and do it before the March 23rd track day i reckon, just see how it goes this saturday !
If it's the first time, take it at your own pace. Unless you're going to go mad for consistent laps you won't have any issues with brakes etc. Go out, have a feel, increase the pace slowly, do a quick lap...then a slow and repeat...keep eye out on temp gauage you'll be right.
From what I hear they dont care, dont think the track will do any timing so if you want to know its up to you to have your own device ?
I dont have one yet, I will have an action camera on the front maybe but thats about it.
Few track days people have put up th receiver near the wall (main straight), but usually with a mate next to it .... besides that use the iPhone Laptimer App with the suction cup (as you've seen before Steve lol)
Bobby - you'll boil that fluid! Mallala is commented on being the hardest track in Aus on brakes.
Throw some hi-temp brake fluid in there, and if you've got stock pads, you'll NEED another set to throw in on the day. I was metal on metal after my 2nd session on my first time out.
Also, dont get too close to the car in front as you're engine will overheat.
Did this ^ for 6 laps, started getting blowby thru the rings & the engine overheated big time, next track day the engine blew. LOL
What brake fluid and pads do you recommend Brendon ? , If I change the pads I dont want a new pad thats going to demolish my rotors .
I guess sourcing them this week could be a struggle ..... :unsure:
What brake fluid and pads do you recommend Brendon ? , If I change the pads I dont want a new pad thats going to demolish my rotors . I guess sourcing them this week could be a struggle ..... :unsure:
QFM A1RM pads and some kind of motul brake fluid? The A1RM's I have on my GTR and they are insanely good
-D
QFM Hpx from GSR Rallysport would be a good start - very quick postage!!! Im sure you'd have them by weeks end if ordered today.
Cheap for what they are, in terms of stopping power.
As for fluid, Penrite SIN Brake Fluid 600 is cheap & readily available from Sprint, Autobarn, etc. Hi-temp goodness.
By the way - 'Speed Bleeder' brake bleeding nipples are the best invention, ever :)
spoke to GSL, really nice guys . They said A1RM would be better than HPX also, but they said dont bother for this saturday unless I can get my disc rotors cleaned up from the old pads.
^^ As per above. Not name dropping, but just got Shaun from Boostworx to do mine before Time-Attacks etc. In saying that, I've had the same pads for the past 2 track days and the Time-Attack!
As per Brendon's comments, just do a few hard laps..then back off and do a cool down lap. Remember not to apply your hand brake when in the pit area once your car is parked as it affects the brakes also (was told by Gary Baxter from the Supercar V8 utes).
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
