On a turbo car its pretty much spot on 12:1.
Any leaner you will notice a drop in power any richer you will also notice a drop in power but also a drop in fuel consumption.
Having a good set of spark's that can ignight the fuel better in leaner conditions also helps with the power/fuel consumption.
i.e Iridiums over coppers.
All in all we are pretty much talking hardly noticible unless you are under 11:1.
Also as a note I run a fuel pressure reg bleed kit to bring the af's in scope.
With the std fuel pump i could tune it well running 1 bar.
I slapped the 910 fuel pump in and i had troubles as the mid range was still the same but the top end became really really rich where as before the std pump started to fall behind with the fuel pressure.
So I lost power up top.
If i tuned the fuel pressure reg to run perfect AF's up top then the mid range was so lean that it would be gutless until 5000rpm and also ping slightly up until then.
This was when I had a std bleed valve on the turbo to make 15psi whcih would drop to 12psi over 5500rpm.
Since I fitted the EBC which now holds 15psi to the red line I can now tune it alot better and with a slight loss in mid range power due to it running ever so slightly lean (no pinging but) nothing like when boost was at 15psi then dropping to 12psi.
Lesson either get a Adj. Fuel Pressure reg and adj. fuel that way if you have troubles with the std pump not handling the high boost.
I'm not sure if the Fuel Pressure reg bleed kit would help fine tune the fuel pressure reg or not though.
Some one with a little bit of knowledge of the fuel pressure reg's would have to shed some light on that one.
https://www.sau.com.au/forums/topic/4193-airfuel-ratios/#findComment-67612
Yer it is a little rough but it is cheap and if set up it will gain some economy and power.
I'm not sure how much bleed valves are I think they are around $70-80 not quite sure plus the one way valve another 20 or so thats $100 plus dyno time..
I had Tim do it at RPM as a development type thing when he was first looking in to it.
The SAFC is a very good cheap option but.
https://www.sau.com.au/forums/topic/4193-airfuel-ratios/#findComment-67657
On a R32 a factory remap is around $500 inc. all dyno time etc..
I just had a look at the turbo smart bleed valve and the cheapest they had was 100 or so..
So the simple cheapo bleeds must be at least half that you would think..
I might do the cold air intake this weekend and slap a nice filter in the std box. :)
See if it nets me any more RWKW's....
Probably wont but.
https://www.sau.com.au/forums/topic/4193-airfuel-ratios/#findComment-67677
How do these new Iridium IX spark plugs affect the performance of a motor that is running slightly lean as apparently it says that they light the mixture better under lean conditions.
Mine is ever so slightly lean for the first 1000rpm when it comes on to boost like 3k-4k due to the fuel pressure bleed. Tim said that its not a critical area and that it wont hurt it..?!?!
https://www.sau.com.au/forums/topic/4193-airfuel-ratios/#findComment-67973
I wouldn't recommend you remap the ECU. At least with a SAFC if you do more mods it's simple to adjust.
I'm running a SAFC and when I got it dyno tuned I still had shit plugs in that were gapped at 1.1mm. Running 12psi it kept missing so i got the SAFC tuned at 10psi and now have an AF ratio of about 12:1. I then put Iridiums in and...wow! Up top there is heaps more power at 12psi.
You dont want it running lean with boost comming on...not good for the engine.
https://www.sau.com.au/forums/topic/4193-airfuel-ratios/#findComment-67998
Yer I know its bad..
Tim keeps saying its not lean enough to do any damage, but who knows sit up a hill at the certian rev where it runs slightly lean with full boost and every thing will get hot and probably burn the crap out of the valves.
https://www.sau.com.au/forums/topic/4193-airfuel-ratios/#findComment-68012
Optimal for any engine is 14.7:1
What absolute crap. As has been mentioned already, different tuners aim for different numbers based on their engine hardware, experience and ultimate goal. Manufacturers (Subaru, Nissan et al) are notorious for releasing cars with ratios dropping at some points to low 11's to safeguard their fickle motors.
In short, get your car tuned by an expert, on a chassis dyno and make sure you have the right hardware to suit your purpose. e.g. S-AFC/pump etc.
Cheers.
https://www.sau.com.au/forums/topic/4193-airfuel-ratios/#findComment-68198
why not remap the ECU?!?!?!
with 256 data points (im pretty sure)
it costs $500 the first time as you have to buy the new ROM, reburn the maps and then epoxy or whatever the ROM onto the board
after that it gets cheaper (around 300) to get another remap
an SAFC costs $500 alone, plus fitting and tuning. in the end the SAFC is only 'tricking' the ECU into thinking there is less/more airflow so is not a long-term solution for a high-powered car
https://www.sau.com.au/forums/topic/4193-airfuel-ratios/#findComment-69336
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
    • It's needed for rolling idle up, and I think it is a decider on VCT also.
    • I mean, not really. Link ECU's can absolutely still have errors from the ECU thinking it's getting a sensor it's not expecting. I would imagine the speed at the ECU level in Nistune does absolutely nothing anyway? I assume the ECU does not do any fancy TC stuff with regards to front+rear wheel speed or anything of that like anyway. Someone who uses Nistune may be more fluent in it.
    • Not yet quite as bad as what we've seen a Jim Berry clutch do in an R32 GTR though when it decided to cut a chassis rail in half... Still very very gnarly and a great reason to avoid.
