Hi I'm having an issue with what I think is my brakes, I can feel a sort of shake or rattle coming from my brake pedal when I brake heavily from a high speed. I'm not sure if it's my brakes, suspension or any other issue such as a loose part along my axle. It feels like it could be coming from the front end but I'm not entirely sure.
Just wondering if anybody has some advice on what I should be looking around, I drive an R34 25GT.
Thanks in advance for any help
https://www.sau.com.au/forums/topic/419397-shaking-rattling-while-braking/
I have the same problem- front end shudders /vibrates under high speed braking. The other thing is a bit of 'sticking' on very low speed 1st and second gear upon initial start and go and then it goes away after a minute or two of driving.
Im thinking its the cold uneven rotors causing this, once it warms up a bit then its fine, am I wrong??
Nah it only happens under high speed braking, it wouldn't be because they are cold in my case, because I drive for about 20 minutes through town until I get out of town on my way to work. Then there's a couple of long straights where I really get my speed up. So they should of warmed up by then.
I had a quick look at my rotors and they look pretty smooth, haven't had a good chance to get my wheels off and have a proper look yet though.
If the brakes were sticking at start up, then it would be the rears because of the handbrake being applied. That's what I would think anyway
What's the average cost of getting rotors machined or fixed up? I was looking at getting an upgraded brake kit, but I wanna wait until I have my new rims first
When I said:
Could be ABS.
I meant it could be the ABS actually working.
Generally, most other "problems" mentioned in previous posts cause a vibration up through the steering column. ABS generates a pulsation through the brake pedal as the unit continuously applies / releases the brake pressure.
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
