bit of news on the car the past 3 weeks its up in damos shed (DJRIFT) having wiring fixed and the manual gearbox rewired we had our ups and downs with the manifold after finding the mild steel manifold i brought pushed the dump pipe across to much so the turbo wouldn't fix and ended up staying with the stainless manifold after dr damo come to the conclusion that it was not the manifold that was at fault but the gasket as i was using a multilayer type that everyone seems to speak so highly of but the layer are held together with small rivets and that was holding the manifold out just to make it leak so i went and got a factory nissan one as directed by damo and the factory one are alot thicker spent the rest of the time pulling the manifold on and off because of stripping the thread on of the head but ended up getting it on and nice and tight and started the car was amazed NO MANIFOLD LEAK :) wiring for the gearbox was done horn and high beams fixed so i can pass pits with it then had a look at the steering as ever since i got it had very heavy steering like there was no power steering after looking it to it more found that from factory the club L laurels have a sporty steering on/off switch in the cab but never seemed to do anything when i flicked it and damo was about to power the unit up that controlled the steering and was like magic steering felt amazing just how it should he then wired it in to the ignition and works perfect now... Soo now its almost there just need new turbo and a tune get rid of that shit ebay one and get the car regoed was think of getting a quick and cheaper tune by fuletech just for now till ive saved up for the new turbo and dyno tune im happy to say its 70% done!!! :)
ohh ok ive never seen a laurel made one what im really looking for is a strut brace that not only goes from tower to tower but braces off the fire wall as well ive seen some before but no idea on where to get them from anyone seen them before
ohhh wow thats a good page thanks for that i have a forward facing plenum so wont have to worry about clearing the throttle cable if s13 fits just hoping i can find one that braces to the firewall that fits..
new turbo brought :) kinugawa T67 thanks to discotune :) quickly ripped the other turbo off and test fit the 67 and the front housing is so big its hitting on the rocket cover so a mates going to notch the cover through the week and give it another go next week end i also started the car with out the airflow meter plugged in and car continued to run fine so must be running off the ems map sensor so i wont worry about putting the afm back in and fingers crossed they just never worried about taking it out??
and still waiting on a gate spring but once the turbos on its off to get tuned and rego!!!!!
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
