bit of news on the car the past 3 weeks its up in damos shed (DJRIFT) having wiring fixed and the manual gearbox rewired we had our ups and downs with the manifold after finding the mild steel manifold i brought pushed the dump pipe across to much so the turbo wouldn't fix and ended up staying with the stainless manifold after dr damo come to the conclusion that it was not the manifold that was at fault but the gasket as i was using a multilayer type that everyone seems to speak so highly of but the layer are held together with small rivets and that was holding the manifold out just to make it leak so i went and got a factory nissan one as directed by damo and the factory one are alot thicker spent the rest of the time pulling the manifold on and off because of stripping the thread on of the head but ended up getting it on and nice and tight and started the car was amazed NO MANIFOLD LEAK :) wiring for the gearbox was done horn and high beams fixed so i can pass pits with it then had a look at the steering as ever since i got it had very heavy steering like there was no power steering after looking it to it more found that from factory the club L laurels have a sporty steering on/off switch in the cab but never seemed to do anything when i flicked it and damo was about to power the unit up that controlled the steering and was like magic steering felt amazing just how it should he then wired it in to the ignition and works perfect now... Soo now its almost there just need new turbo and a tune get rid of that shit ebay one and get the car regoed was think of getting a quick and cheaper tune by fuletech just for now till ive saved up for the new turbo and dyno tune im happy to say its 70% done!!! :)
ohh ok ive never seen a laurel made one what im really looking for is a strut brace that not only goes from tower to tower but braces off the fire wall as well ive seen some before but no idea on where to get them from anyone seen them before
ohhh wow thats a good page thanks for that i have a forward facing plenum so wont have to worry about clearing the throttle cable if s13 fits just hoping i can find one that braces to the firewall that fits..
new turbo brought :) kinugawa T67 thanks to discotune :) quickly ripped the other turbo off and test fit the 67 and the front housing is so big its hitting on the rocket cover so a mates going to notch the cover through the week and give it another go next week end i also started the car with out the airflow meter plugged in and car continued to run fine so must be running off the ems map sensor so i wont worry about putting the afm back in and fingers crossed they just never worried about taking it out??
and still waiting on a gate spring but once the turbos on its off to get tuned and rego!!!!!
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
