should be making over 300 on that boost with that turbo so deffs something wrong there
yeah as i said i have problems with ecu sensors jumping all over the place so it is only a half tune and im not really going for max power
  • 3 weeks later...
need to think/find a new muffler/pipes for the back as the cannon thats on there sucks ass and im thinking twin tip but not sure even another cannon that looks better and sounds better would do please discuss!!!
spent saturday down hobart helping frenchie out with his bus at the round 3 drift day was a good day besides small miss hap that ended the day but the day gave me a boost to do a bit of work on mine today as im still waiting for wiring to get down before it can go back to have the tune finished :down: so just done some fiddly things started fixing a dicky power window and after taking the door trim off found the car had the intrusion bar cut out and a large rhs frame welded in to the door like a heavy duty crash bar or something super strange and have no idea why its been done as the doors have had no repairs or new skin welded to it
other news brought first pair of wheels vskf in 17x9 +18 and have another pair soon 18x9.5 +18
hks oil cooler and oil filter relocation on the way a stainless twin 3inch pipe being made
damo come done last of the wiring on saturday air temp sensor in earth for the ecu fixed power steering fixed heap of wires cleaned up and neatened and is going back in to have the tune finalised this week and some actually good power figures will be up soon the kfs and going in tomorrow to have tyres changed over and try to get them back on and ply with camber and what not to make them fit ready for tune
well not the best news.. after having the wiring issues fixed on the ecu what we thought was a bad earth that was making the sensors (tps,water temp) gitter and making the motor run super rich i then took the laurel back to the tuner (boost automotive) car had to stay there for a day or 2 as he had to tune the cold start and finalise everything else got a text the next morning and was told the car is still not right and is still all over the place as you can imagine i wasn't after stuffing around with the car for so long and and this ecu so that night wiring mate (DJRIFT) went back through the wiring trying to find a bad earth or bad anything started to think as the ems runs off the ome ecu some of the sensors may of been doubled up and that was making things gitter and go all over the place fixed a few wires sent it back there the next morning still no go better but still no go so this weekend we went back over everything with a borrowed laptop to see if we could get it to work we really went through everything tested every wire and every ground nothing we could do seemed to fix the gitter :( we pull the ems out to check the ecu its self we found what may be sign of water damage and to the computer its self so in the end we have out it down to that the ems ecu has shit its self pretty much from water damage or just from age or bad luck and have now been set back more with having to buy a new computer and im not going to put a cheap half ass computer in it im looking at a haltech platinum pro unsure just sad on the hole car at the moment waaaaa :down:
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
