Hey boys, as in topic title my drivers side drive shaft boot is wide open and I suspect it's been like that for a while as grease is all over suspension arms.
The question is what is the most cost effective way to repair the boot and where or to order whole new drive shaft from Nissan?
Anyone had this problem?
I have inquired at local drive shaft repair joint where for more common cars you can simply get a swap for a repaired DS, not for Stagea and he has never seen one repaired?
Thanks
David
https://www.sau.com.au/forums/topic/419675-2002-m35-drive-shaft/
The boot isn't that hard to change man I had never done one before and it only took me like an hour to do. So was not to bad, but if you find the part number let me know :-)
Are you talking about the inner boot or outer boot? The guy at the repair shop said that he could maybe find the match but inner is the problem???
just go to your nissan dealership and order some dont use universal ones as they aren't as good.......... ill look part numbers up or Daleo should know LOL
found this too.......... (note drivers side inner and passengers side inner are a different part number, but outsides are the same)
also try the search function next time as this has been covered a few times :)
Sorry man didn't mean to bring up stuff being covered, Thanks for the info and I'll try nissan first but part numbers will make it easy.
Cheers
Dave
Notice the part for the boot has a star, not a part number. Nissan ordered some of the other part numbers in for us but none were the inner boot. A driveshaft shop would be your best bet. Or there are also Various Nissan boots on ebay that look similar, could be cheap to try and order one off measurements...
Just a quick update on this issue,
After all the searching and calls to nissan I've decided to do it the easy way which is called Greg from Autosport Kirawee (02 9521 1388) who said yep we have them in stock and all done cleaned regreased and fitted within two hours for a resonable price what a service.
I have used them before for gtr work (4wd didn't work) very familiar with imported cars and performance kind of work.
Would highly recomend them especially if you not DIY kind of guy or just busy.
Dave
    • Echo the awesome sentiment 👍 Definitely a car worth saving. Looking forward to seeing updates as well.
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
    • The maxpeedingrods turbo is cheap and bolts on to stock parts. I think you just need a bigger silicone coupler for the intake. Its a cheap china turbo, but it's been running on mine for almost 3 years at 16-19 psi.
    • What do they look like right after you've tried to start it with everything connected? Also post photos of what they actually look like.
