I have scoured SAU and the web and I did not find a answer to this.
I have series 2 AWD auto stag, which is completely stock except for a manual boost controller which I have just put in.
I know I will have a restrictive exhaust system (it is our family wagon, and I like how quiet it is), and I wont get much more power out of it, but it gets up to full boost and power noticeably faster now, and that's all I was after. Handy at the lights ;-) and for overtaking. Off the mark till about 40km per hour, it was slower than the Manual Subaru Outback that I used to have!
Anyhow I am currently running 9psi. Can I go to 10 or should I be running less? Is back pressure going to hurt anything?
Any advice will be muchly appreciated!
Thanks guys. 0.7bar. and 0.8bar is 10 and 11psi. I'm running 9 and will take it up to 10 when it cools a bit in a couple of months, just to play it safe. I don't take it on a track lol, and live in a rural area with bugger all sets of lights, so I dont stomp on it very often, so my SMIC will do the job. Its just nice to have the power there when you need it or want to have a little fun! Just bypassing the boost solenoid with the boost tee and running stock.
I put my boost gauge on before the MBC and (from Memory) found it would boost to 6psi at 2500rpm then switched over to 8psi art 4500rpm.
After MBC I set it to 8psi, and found I got 8psi even before 2500rpm. This alone has made a big difference in power delivery! a couple more PSI and its a different beast. Great bang for buck!
Ill look into a quiet 3inch all the way when I have some money. Its got to make a difference, particularly to the top end power, which my little mod has not gained very much of.
    • Even more fun, leave all the ADAS stuff plugged in, but in different locations, hopefully avoid any codes!   And honestly, all these new cars with their weird electronics. Pull all the electronics out Duncan, and just shove an aftermarket ECU and if needed a trans controller in, along with a PDM. Make it run basic but race car styled!
    • To follow up a question from earlier too since I had the front bar off again (fking!) This is what is between the bumper and the drivers side wheel And this is the navigator side, only one thing but its a biggy! So basically....no putting coolers in the wheel arches without a lot of moving other stuff. Assuming I move to properly race prepping this car I'll take that job on and see how the computers respond to removing a whole bunch of ADAS modules
    • So I prepped the car for another track day on Wednesday (will be interesting to see coolant temps post flushing out and the larger reservoir, with a forecast of 3-14 being 20o cooler than last time I took it out). Couple of things to mention; since I am just driving the car and not taking a support vehicle, I took the rear seats out and just loaded the back up Team Trackday style. Look at all that space! To cover off removing the rear seat....it is weird (note the hybrid is probably different because it wouldn't have folding rear seats) Basically, you remove the lower seat base, very similar to a r series but it is a clip that pulls forward to release the base rather than it being bolted down. Easy Then, you need to remove the side section of the rear seat on each side. There is a 14mm head nut at the bottom of the side piece, the it slides upwards off a hook at the top to release; you also need to unhook the seatbelt from the loop at the top. Then the centre piece is weird. You need to release/fold the seats forward with the tab in the boot on each side From there, there are 2,x12mm headed bolts holding the rear of each seat to the folding bracket, under the trim between the rear seat and the boot (4x christmas tree clips there, they suck). The seat is out but you can see where the bolts attach to the bracket
