Have just put new rb30 into r32 with rb25de head and rb20 cams. Since I've tried running it it idled like a dogs breakfast and stalls and in doing so the apexi avcr is saying injectors are at 90% duty cycle at idle. Car will running and revs out and when warm is ok but the idle starts to hunt from 1000 to 1500 also the idle at 800 is like its miss firing but its not. I have new temp sensor new coil packs new plugs new coil harness and the list goes on. The one plenum is a side intake and the aic valve sits underneath. Can anyone helps please. This making me pull my hair out.
https://www.sau.com.au/forums/topic/419823-new-rb30-running-like-crap/
Could be a miilion things.
Has that ENTIRE setup come out of another running car or is it a freshly built engine with all the newly acquired parts used to put it all together?
What computer are you running? Has is been tuned at all to run on the current setup?
Is there a vacuum leak? Old fuel?
There's a whole lotta variables that you're going to have to go through one at a time in a logical order.
Good luck!!
Thanks mate. Yes all is new and its waiting to be tuned has bigtime in it. Found out it was typical aac valve issue but now its missfiring on cylinder 6. Has spark has fuel. Has new coil packs plugs coil loom and freshly clean injectors can't seem to isolate the issue. Ignores has good resistance and signal. Any help on that?
There was a guy just last week that found he had low battery voltage and that was enough to drop a couple of cylinders so try that first.
Have you swapped coils/injectors/spark plugs from cylinder 6 to see if the problem moves? If not do each item one at a time.
^^^ damn dude. ok so check low voltage. well today i pulled the coils out and swapped them with 3 others plus a spare nissan set i had in the shed with a spark tester and it has spark on every single tested coil pack i also pulled the injectors and checked that they have flow and swapped them around and ALL injectors have flow. also recalibrated fuel pressure regulator as it was getting 100psi pressure....................................??? anyway didnt fix the issue my ecu has a nistune daughter board it it to so what voltage should i be looking for from a skyline alternator?? 14.4v?? also now engine wont stay idling just dies pissing me off big time this has cost me 30k to build this thing.
Get a stock computer and try that (one that matches the head/wiring you're running).
It sounds like you might be on to something when you say it only plays us when bolted down. Possibly coil pack harness? Try one of those too if you can get your hands on one.
cas works well tested it, sctraching my head bout ecu been lots of rain here lately just did code check on ecu came up 55. has z32 afm wondering if that maybe an issue with old wiring i know alot of people fall on that too and doesnt come alot as being wrong will try sitting coil pack on head with a lead running from coil pack to plug tomorrow. timings right. it has rb25de head on forged rb30 awd bottom end in a r32 gts4 stock cams fully recoed head and new 100lb valve springs arp head studs and rb26 head gasket. so i'm ruleling out compression issue. stupid thing has piston slap above 1500 rpm in 1st cylinder though thats another story i know what i have to do to resolve that. theres not much that isnt new on it. maybe needs more earthing out from block???
any number of reasons (including the above) for cylinders to randomly drop. . . when mine did it -turned out the stock ecu was as crook as a chook
forgot to add. .electrician told me some of the pins on the wiring loom(going into the ecu) was a bit dirty , when you moved the ecu with the engine running it would sometimes drop a cylinder or just stall, maybe if you sniff around there you might find your problem
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
