Hey guys just bought this nistuned Z32 ECU.
ECU no# 23710 46P00 which is the correct 8 bit ecu to use
Also has the type 2 Nistune Daughterboard to suit S1/S2 R33.
Reason for selling is, i was told it was to suit s2 However after pulling it apart to inspect quality of ECU modifications required to suit r33, i discovered that it has been modded to suit series 1 and not 2. I am an electronics tech and all the modifications are done professionally.
I can revert this to suit r33 s2 but as it has cut tracks to suit s1 and removed resistors it would be a pain to do.
Price is $465 posted this is exactly what i paid last Friday.
Price is superfirm as in the case where it doesnt sell, i will put in the effort to suit the s2.
Feel free to ask any questions
Cheers
Patrick
https://www.sau.com.au/forums/topic/419901-nistuned-z32-ecu-suited-to-s1-r33/
    • After chasing my tail with LS results..... and cheaper than a turbo swap... How confident are you that the dyno is accurate relative to other results? How fast is the car - What MPH does it actually run? Is this similar to what people running this power would expect?
    • Hi mate I am having an identical issue with my 98 R34 GTT. The engie suddenly cuts out under load at about 3-4k, black smoke out exhaust. Almost feels like traction control kicking in. No CEL but still going to check codes later today. Car was sitting in the shed for about 5 months before hand and only idled a few times, took her out with about 1/4 tank, filled up and thats when the issues started happening.  Threw on a spare set of coils/harness and checked plugs which was no help. Recently had fuel pump/filter changed so surely thats not the issue unless condensation in fuel, I just havent had the time to drain it It's running a hi flow turbo, bosch 1000cc injectors, walbro 450L, Z32, Nistune etc... All about 2000km old.
    • I always wonder where the obsession with legal/illegal spacing on number plates in the UK comes from. Because it comes up in comments in every UK-based video I see on youtube. From my point of view all of your plates look a bit odd. Just because there are no markings whatsoever. In Australia we have the state that has to be on it. In Europe you get stamps and state logos. Yours look a bit like a throwaway draft that people then stuck with. And attached with blu tack so that it falls off at the slightest disturbance. Not trying to hate, but it's interesting how things are done in different countries. Do you have to follow a lettering convention when choosing a custom plate?
    • Hybrid sounds like a supercharger... It's half a turbo, with a belt to drive it! Oh wait, they're just called super chargers...
    • It's either an ignition failure or a fuel failure.
