Well, today is an exciting day for me. I have been after this car for the better part of two years.
After tracking down the lady who’d been driving it, i found out it belonged to her uncle who owned it since new and he’d lent it to her ten years ago! He wasn’t really interested in selling it but after calling up to check every couple of months he finally relented. I had wanted this one to be my tenth R31, but i bought the silo 5 days before as a fixer upper. The simmons will be going on the gts until i can source another pair
It is quite rough on the outside as you can see and the interior needs some work but thats exactly why i’d wanted it. It seems to have all the original bits except for two of the rims – developed the cracks – but im sure any GTS aficionados will help pointing out whats needed smiley.gif
Standard tape deck!!!
Standard speakers?
  • Like 1
well the real miracle about finding one of these is that pete has personally killed more nissan actually made. On the bright side he would have left lots of bits at wreckers
Thanks guys. Im really suprised at how well it drives, handles better than any of my other street 31's
Did a bit of a clean, needs a lot more work but it feels nicer now. The polish worked, it'll need a cut though but im not sure how much paint is left. There’s bare metal on the bonnet
I don’t know if i mentioned it before but the car got broken into a couple of weeks before i bought it. so i had to replace the loom behind the ignition, now i can start it without having to jump the starter haha.
I’ve also ordered a new ignition barrel with extra door lock barrels
Did an engine oil flush as it was blaaaacck and new tank of premium with injector cleaner in it. Must have been some sh1t in it, stalled on me about 20min later and had to floor it to start again with a big puff of smoke. Running much better/smoother now.
Also, I tried to adjust the front bar gap. I think the reo is bent so for the interim i pushed the right side up and pulled the left down so theres about a 10mm evenish gap now. No pic atm
Haha, yep. Got a set of Simmons V4's to go on, just need to get a lip straightened on one.
The ones you see on the silo in the first picture.
  • 1 month later...
New number plates finally got here and i put the fog lights back in at the same time.
Also, shiny new O2 sensor. The old one had a rattle..
Cold idle is new and improved.
  • 8 months later...
Funny you posted now :)
I only just put rego onit and drove it for the first time since june.
But other that that, I haven't really done much to it. Been on the back burner while I've been playing with grumbles :)
    • Nah, don't bother doing any actual measurements on the car. Just go ask the inter-f**king-net.
    • I currently have 18 x 9 +30 on the front with 18 x 10.5 +38 on the rear. Absolutely regretted it. Ended up putting 15 mm spacers on front and 25 mm spacers on the rear. Not to mention the rears were like a mm from hitting the coilovers. Definitely would go more aggressive then what you were originally planning. Keep in mind my guards are rolled and cars fair low so you might possibly need to roll guards depending how aggressive you go and how low the car is. Im not an expert but the 18 x 8.5 +25 18x9.5 +30 Sounds like it would sit much better.
    • Hey guys, sorry i have been researching for a few months and absolutely cannot wrap my head around this. I am about to order some rims to fit my R34 Gtt with coilovers My original plan was to order Rota grid R in 18x8.5 +30 235 40 R18 Fronts 18x9.5 +35 255 35 r18 rears But then the thought in my head said this isnt aggressive enough. I want the most concave spokes i can get without too much of poke and scrubbing   So my thoughts now is  18x8.5 +25 18x9.5 +30   My question is will this be the most aggressive i could get it without any guard rolling and does the type of rim style affect the offset / size.   Thanks everyone.
    • Lower parts are there. On passenger seat, bright yellow bit is the release mount. On drivers, bright yellow bit is the lower buckle for the other side. My bet is lowers are tucked out of the way as much as possible for visuals.
    • I'm guessing its a 4 point harness, 3 of the 4 belts are visible. I'm guessing the hidden belt is tucked down between the seat and door.
