Hey ppls.
I'm looking for some photos of aftermarket gauges in the R34 GT-T Centre dash three gauge pods.....
I know Ben Ellis' R34 had them but I don't have back issues that show them.
I need to know whether they fit easily and had big they need to be to fit....
And know, I don't want the tv screen to replace them, even though that would be nice, I can't think of anything which would be more appealing to thieves!!!
All help appreciated
BASS OUT
https://www.sau.com.au/forums/topic/42005-gauges-in-r34/
Hi.
I'm pretty sure they must be 52mm (definitely not 60mm as they will not fit). HKS, Defi and Omori make 52mm gauges (there may be others) but you will have to look around for pics. Try looking at www.perfectrun.com.au for pictures.
Good luck and post your results for all to see as I am sure there are others with the same curiosity.
Cheers.
https://www.sau.com.au/forums/topic/42005-gauges-in-r34/#findComment-863572
I have a 52mm Air/Fuel ratio gauge and this was too small when I tried to see if it would fit!
I think it needs to be closer to 60mm, probably a "non-standard" size :D
The problem is often the face or Bezel of the gauge, the gauge body itself is not really an issue if the front of it fits!
Good Luck.
I ended up getting some metal fabricated which I inserted below the stereo, this accomodates 2 X 52mm gauges, I just need to buy a decent boost gauge to fill the other hole.
Maybe just buy the nismo ones:
https://www.sau.com.au/forums/topic/42005-gauges-in-r34/#findComment-865140
i guess he has more money than he can poke a stick at :rant: i mean, you can only throw so much money into a car on engine modifications before he goes fully sick mayte on the interior.
all i want is boost, exhaust temp, oil temp and water temp gauges....thats not being picky is it! :)
https://www.sau.com.au/forums/topic/42005-gauges-in-r34/#findComment-868169
    • I don't know for sure, but I'd expect them all to be interchangeable given the diff end and hub end don't move/change between any C34 series. Often Nissan will change part numbers and the aftermarket follows those year ranges; but the original part number change doesn't mean other parts won't fit. The change could be a change in material, internal parts or even just supplier. For example, all the RB gearbox to engine bolts are no longer available and there is a new part number instead. The only change is they went from cadmium plated bolts to zinc plated due to the issues manufacturing with Cadmium. They look different but work the same.
    • One year is a bit concerning. Did you try contacting GSP? It says 5 year warranty on the box if I remember correctly. I'm also running their driveshafts on my S2 Stagea.   You could check the part numbers on Amayama for your year. Here's the link for my 1998 which gives the 39100-23U60 part number. Well, that and 39100-23U70. https://www.amayama.com/en/genuine-catalogs/epc/nissan-japan/stagea/wgnc34/6649-rb25det/trans/391 What does it say for yours?
    • I ordered a GSP Front R/H Axle from here - https://justjap.com/products/gsp-premium-front-driveshaft-r-h-nissan-r32-r33-r34-skyline-gtr-stagea-4wd#description It lasted around a year before one of the boots blew out. I'm lowered, but I have GKTech roll center adjusters. One year seems a little premature. I think I'm going to spend the extra money on an OEM cv axle this time. This website - https://tfaspeed.com/collections/nissan-stagea-wgnc34-x-four-parts/products/nissan-stagea-awc34-260rs-rb26-right-front-axle-drive-assembly Makes it sound like the readily available OEM CV axle will only fit 11.1999 Stagea and up (mine is a 2.1997 S1). The JustJap listing didn't mention any years or anything for the GSP axle. Amayama shows '11.1999' and up as well for that part number. As well as 'plastic boot type'. See attached picture. So I guess my question is, does that axle (39100-23U60) really only fit S2 Stagea? It's the front driver side. If it does, I'd love to buy that instead of rolling the dice on another GSP. I've found that OEM one cheaper here: https://www.partsfornissans.com/oem-parts/nismo-jdm-r32-r33-r34-skyline-gtr-r32-gts4-right-front-axle-3910023u60 and here https://www.nissanparts.cc/oem-parts/nismo-shaft-ft-drive-3910023u60 Just a little confused because the JapSpeed listing for the GSP front driver axle doesn't mention any specific years or anything and it fit my S1 Stagea fine. So will 39100-23U60 fit my S1 Stagea even though technically it says '11.1999' and up? What would have changed? Thanks.
    • Thanks for the info. The only "Issue" I've had with the shifter is I always found the throw between 4th and 6th gear too close. I'm always worried to shift into 4th accidently and sending my motor to the moon. Adam LZ recently came out with a video and stated Serialnine revised their shifters to correct this and will change all the revised parts for 150$. Strangely enough, I contacted Serialnine right after and they denied it and said it's bullshit. I found that strange as he's a distributer. I'll keep this forum post updated on that saga.
    • Yep that is correct. It allows you to adjust the short throw range from what I can tell
