r34unit Posted February 18, 2013 Share Posted February 18, 2013 Is it possible to fit a cooling pro intercooler kit or a hdi intercooler kit in a r34 gtt without cutting a hole for the cold side ! I have a mate that when he had his skyline a few years ago, said he installed a hdi kit with out cutting any holes . Has any one else achieved this ? Link to comment https://www.sau.com.au/forums/topic/420171-true-or-false/ Share on other sites More sharing options...
SiR_RB Posted February 18, 2013 Share Posted February 18, 2013 Yes if it's a return style intercooler kit which uses the existing cooler pipes holes in the passenger guard Link to comment https://www.sau.com.au/forums/topic/420171-true-or-false/#findComment-6756586 Share on other sites More sharing options...
ARTZ Posted February 18, 2013 Share Posted February 18, 2013 There's Another way Link to comment https://www.sau.com.au/forums/topic/420171-true-or-false/#findComment-6756664 Share on other sites More sharing options...
GTSBoy Posted February 18, 2013 Share Posted February 18, 2013 You can run the cold pipe under the front rail. Leaves it hanging down in the weeds a bit though. Link to comment https://www.sau.com.au/forums/topic/420171-true-or-false/#findComment-6756739 Share on other sites More sharing options...
r34unit Posted February 18, 2013 Author Share Posted February 18, 2013 You can run the cold pipe under the front rail. Leaves it hanging down in the weeds a bit though. Have u done this or do know any one that has ? Pics ? Cheers Link to comment https://www.sau.com.au/forums/topic/420171-true-or-false/#findComment-6756885 Share on other sites More sharing options...
GTSBoy Posted February 18, 2013 Share Posted February 18, 2013 I have a return flow setup. Haven't seen an under rail install in 10 years. Link to comment https://www.sau.com.au/forums/topic/420171-true-or-false/#findComment-6756924 Share on other sites More sharing options...
scotty nm35 Posted February 18, 2013 Share Posted February 18, 2013 Either go with a return flow, or you will need to get creative. I have fitted many different cooler setups to Stagea's and Skylines, all of which are on here somewhere if you search. Link to comment https://www.sau.com.au/forums/topic/420171-true-or-false/#findComment-6756931 Share on other sites More sharing options...
ARTZ Posted February 18, 2013 Share Posted February 18, 2013 they are? where do you hide all this creativeness i never see it? Link to comment https://www.sau.com.au/forums/topic/420171-true-or-false/#findComment-6756945 Share on other sites More sharing options...
r34unit Posted February 19, 2013 Author Share Posted February 19, 2013 i cant find any info or pics about running the cold side with out cutting any holes !but he is 100% sure he did not cut any holes in his r34 Link to comment https://www.sau.com.au/forums/topic/420171-true-or-false/#findComment-6757619 Share on other sites More sharing options...
scotty nm35 Posted February 19, 2013 Share Posted February 19, 2013 Yours is on here Artz, and I have done a few coming up beside the radiator, it's quite tight through there though. (works better on the S14/15) Link to comment https://www.sau.com.au/forums/topic/420171-true-or-false/#findComment-6757652 Share on other sites More sharing options...
r34unit Posted February 26, 2013 Author Share Posted February 26, 2013 Can any help me with some pics or links ? Link to comment https://www.sau.com.au/forums/topic/420171-true-or-false/#findComment-6765643 Share on other sites More sharing options...
GTSBoy Posted February 26, 2013 Share Posted February 26, 2013 Just open your bonnet and have a look at where the pipe could/would run if you were to do it. Link to comment https://www.sau.com.au/forums/topic/420171-true-or-false/#findComment-6765647 Share on other sites More sharing options...
r34unit Posted February 26, 2013 Author Share Posted February 26, 2013 I see where it could go but don't know about the clearance between the ground and pipe Link to comment https://www.sau.com.au/forums/topic/420171-true-or-false/#findComment-6765698 Share on other sites More sharing options...
GTSBoy Posted February 26, 2013 Share Posted February 26, 2013 Clearance = measurement from ground to car - diameter of pipe. If you're happy with the number, run with it. Link to comment https://www.sau.com.au/forums/topic/420171-true-or-false/#findComment-6765711 Share on other sites More sharing options...
eightsixboy Posted February 26, 2013 Share Posted February 26, 2013 Just buy a return flow, why waste time and money on a kit that has to be modified, the cooling pro ones are cheap as chips. Link to comment https://www.sau.com.au/forums/topic/420171-true-or-false/#findComment-6765733 Share on other sites More sharing options...
TTT Posted February 26, 2013 Share Posted February 26, 2013 if you are keeping the standard intake plenum, and are willing to cut up the drivers side of engine bay, get pipework like this..(Gibson motorsport R31 GTSR) If you just want a hassle free FMIC that doesn't involve any cutting of anything, then get a return flow cooler kit from BLITZ. Looks like this.. If you want to spend less and still not cut any holes, then get a cooling pro/Just Jap/*insert other ebay kits here* I sold an ARC return flow kit and replaced it with an R32 GTR core and Gibson motorsport type pipes. Link to comment https://www.sau.com.au/forums/topic/420171-true-or-false/#findComment-6765765 Share on other sites More sharing options...
scotty nm35 Posted February 26, 2013 Share Posted February 26, 2013 Not sure how much room yours has down beside the radiator, and if you want to compromise on pipe diameter, but this is what I do for the s14/s15. Trim the shroud and run stainless down beside the fan. I have also done a few custom installs, here is one with the aircon removed and the pipes through the side of the radiator. With a FFP this would be the shortest possible outcome. http://www.skylinesaustralia.com/forums/topic/190267-summary-front-mount-intercooler-options-piping-layouts/page-3 Link to comment https://www.sau.com.au/forums/topic/420171-true-or-false/#findComment-6765905 Share on other sites More sharing options...
