Over the last couple of years there has been talk of introducing a class within the MS Championship that caters for those nutters wanting to use a slick type tyre.
This includes, but not limited to:
Hoosier
Hankook
Dunlop
Avon
Pirelli
Advan
Bridgestone
It seems this year there maybe enough nutters to actually run this class and provide trophies at the end of the year.
So if we can get a consistent 2 cars on slicks turning up to each round and at least 4 different cars for the year after Haunted HIlls, then the class will be included in the end of year awards. If the numbers are not there, we can still acknowledge you, but you won't get an award.
Please bare in mind that slick type tyre use it up to the discretion of the club running the track day and the use of said tyre is generally dependant on weather conditions. Further more, to be included within the SAU MS Championship on slicks the car much as a minimum have a 6 point CAMS compliant ROPS.
Register your interest here.
Paul has already set a 1.39.x at PI on slicks in the first round of the year.
Bring it on.
https://www.sau.com.au/forums/topic/420333-slicks-class/
Ill be in if there is enough interested parties. Slicks are fantastic compared to r specs, everything is better whilst driving on them except in the rain. It is the best bang for buck mod you can ever do, and you can get heaps more track days out of a set compared to your r specs so your saving $$$.
How bout spicing things up a little also, with fastest timed lap winner at each track at the end of the year??
On another note, John can you get bigger trophies for next years presentation as we could hardly see them...just saying cause I didn't get one.
https://www.sau.com.au/forums/topic/420333-slicks-class/#findComment-6760489
They have been about a meter high in previous years. I'm running out of space to store em, so smaller ones were a must :P
There is an idea for a perpetual honours board for the fastest time for each track for each year.
https://www.sau.com.au/forums/topic/420333-slicks-class/#findComment-6760549
I'm keen to have a go on slicks and move on from std awd so that's 2. Just wondering where does the 6 pt RPS requirement come from? not really an option for a road driven car. maybe 4 pt okay?
Class needs a better name. maybe "unlimited"
https://www.sau.com.au/forums/topic/420333-slicks-class/#findComment-6760594
It's a general understanding that clubs have, some enforce, some don't. In the past WRX have been one that does enforce it.
Either way, commitee has previous agreed that running a slick increaces corner speed a loading and can therefor increase the impact of a mistake.
It maybe a possibility for a 4pt with side intrusion, but that will need to be discussed.
Essentially we need to promote a high level of safety. WTAC mandates 6pt for Open Class and up.
https://www.sau.com.au/forums/topic/420333-slicks-class/#findComment-6760637
Mr datto nailed it... "Unlimited" class is awesome. Have done some piarc days and 4 point cages are allowed with slicks and no side intrusion as the doors already come with this in place as a registered vehicle. Not 100% on the written regards to cage but seen cars running this set up and pass scrutineering every time.
https://www.sau.com.au/forums/topic/420333-slicks-class/#findComment-6760815
  • 1 month later...
2nd that.
Slick class is a great idea. Interesting to see how many take it up. I might later in the year but still have sets of AO's from last year WTAC to use up first.
https://www.sau.com.au/forums/topic/420333-slicks-class/#findComment-6795821
  • 1 month later...
Guest
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - hopefully the motor and other things are OK but yet to be seen too. There is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it Effort doesnt win you races though     Apparently this is motorsport !
    • Thanks, will do that.  Thankfully they still feel great.
    • Yeah man, absolutely. You can try pushing me all the way in swapping the R34 for an E9x M3
    • It's almost certainly going to be some amount of pads compound transfer onto the rotors. It will probably go away after you've run them for a bit. If not, pull it all out, lightly sand the rotors, scuff the pads, and rebed.
    • no one recommending speedtek gearsets?   i'm in the same boat as Cosline but rwd, I am holding boost back in third to 600nm at the hubs to save the gear as i make nearly 750nm at the hubs on a mainline
