But in all seriousness, what Konieegeeseegggaaeese are doing is pretty awesome. It's great to see a legit company coming up with something so far out and with so much potential. Plenty of nutbags have come up with "motoring revolutions" in the past which came to nothing. Koneorofgefefedlknfegsgseg have the runs on the board so it's worth watching.
this had been around in diesel tech for a few years now. Much easier to implement it on diesel as the size of the engine isnt a restriction i.e. plenty of room, and most diesels have an integrated air pump. Also, as it was relatively new tech back when, it was also more suited to diesel as it is a slower moving, albiet heavier system
koenigsegg's are probably my all time fantasy car.
such amazing machines. there's another video in that jalopnik series where the test driver slams the brakes at 300+kph and takes his hands off the wheel.
no squirreling. no pulling. stops dead straight.
mr koenigsegg is such a genuine, enthusiastic guy.
exciting times indeed
CvonK in previous documentaries has been innovative, open minded, motivated and with $$$ behind him, a risk-taker.
To implicate 30% more torque, 30% more power, 30% less fuel consumption & 50% less emissions with this concept, CvonK has much more to offer us in terms of transportation than 'just' a supercar in the years to come.
    • The wideband reading is meaningless if it's not running. Why are you using shitty old sidefeeds on any engine, let alone a Neo? What manifold and fuel rail are you using to achieve that? Beyond that, can't help you with AEM stuff as I've never been their ECU/CAS combo.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
