Oh... I listened to the fax make a connecty sound. Will take a photo of my forms and email them through.
lol so the good news is; the fax hasn't actually been disconnected yet, although it should have been.
the bad news is you faxed the form wrong side up :P so I got 2 blank pages and no idea who to chase!
Chase.... ME! =-D
Nah it's all good. I photo/emailed the same forms through. Last time the same fax machine here at work decided to eat most of the form and pass the second page through without scanning it.
Faxes should have died with 56k baud modems if you ask me. ;o)
Not long now, unfortunately looks like my 32 wont be ready as funds have dried up for a little. But will be comming down once again to help out with timing, sign up and pointing and laughing at crazy driving ;) But definately will be driving in the next one :)
Yes i have it here i shall put it in my car now i also have the number "14" windscreen number that u guys had at the last texi i did, i forgot to give it back :P So thats in the car to lol.
Hi Guys,
I am from Tamworth NSW (about 5 hours away) but should be getting my car tuned in Newcastle on the 29th. Is there someone I can contact on the 29th in the evening to check if there are any spots left or should I post on here? I just want to make sure tuning is all finished and goes to plan before I commit to a day of skids/limiter!
Thanks
Best bet is to check in here and/or come on the day. We will post up in here if it is full.
Even if you don't run would be a great day to come and meet some of your Southern NSW Skyliners.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
    • I got adjustable after market rear camber arm to replace the stock one's because got sick of having to buy new rear tyres every few months. Can anyone please let me know what the best adjustment length would be. I don't have the old ones anymore to get measurements. I'm guessing the stock measurement minus a few mm would do it. Please any help on replacing them would be fantastic I've watched the YouTube clips but no-one talks about how long to set the camber arm to.
    • Heh. I copied the link to the video direct, instead of the thread I mentioned. But the video is the main value content anyway. Otherwise, yes, in Europe, surely you'd be expected to buy local. Being whichever flavour of Michelin, Continental or Pirelli suits your usage model.
