have you ever been through the mallaca straights?
it really is amazing it doesnt happen more often. its not like the ships can just put on the brakes and stop in 100m.
I was heading into singapore once (sailed in there a few times), and at 45 degrees to port and starboard or the bow, I counted over 90 contacts, then I gave up.
https://www.sau.com.au/forums/topic/42054-ship-sinks/#findComment-861509
How the *** do you colide with a supertanker?
Its not like u wouldnt see it coming!
Surprisingly its fairly easy for larger ships to collide.
Problem is that they are very hard to manouvre. You just cant turn them around or stop, it can take a long distance (kilometres)
Often they come across each others path's at fairly late notice and in heavy seas, or fog its all over. In really heavy seas its possible to loose sight of big ships very easily.
Commercial ships are alot different to control than a small tinny or even a 60ft charter boat!
https://www.sau.com.au/forums/topic/42054-ship-sinks/#findComment-861520
that actually happened last week..and it was only about 100 japanese second-hand cars..still a shame though.
I had a friend last week whose car managed to make it safely to Australian shores, only to have a container accidentally dropped on it. doh!
https://www.sau.com.au/forums/topic/42054-ship-sinks/#findComment-861718
    • No requirement for JDM vehicles,  which the 33 is, maroney label only needed in the US market for new cars I believe (Federal law stuff) Google knows all
    • Hopefully you can just unbolt them, thank them for their service, then bin them and not replace them Apparently the sensors like to set them off with only minor impacts at low speed It looks like they do a delete kit for some of these, but, it is costly
    • I hope it's actually possible. This is a write off in insurance world.
    • Yup. 2-way with shallow ramp angles. Still works.
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
