The wire isn't the issue, the afm has an ecu inside it which fails. Could be low input voltage causing it, but I have seen a brand new Nissan afm blow the first time the car was booted, so it definitely isn't dirt or oil causing that fault. The hotwire isnt able to be touched in these really.
The original superseded OEM part number is the one to get, they last many years, it's the new Nissan part number that fails constantly. If only there was a batch of old stock laying around. Until then we are stuck trialling aftermarket afms till we find another good source.
everyone has to get spare one in glove box. my brand new genuine AFM lasts over 2 months, no full throttle during these months. so far so good. btw, i am using KN oil filter
Edited by YangLIU
My Nissan replacement/updated part number sensor is seeing max voltage quite a bit. Will see if it lasts longer than the Chinese one did. Will report back when or if it blows ;-)
What's the max voltage you got? ECU will cut fuel when AFM voltage is over 5.1v
And if you release your foot from acc pedal bit by bit, then you could see the min voltage is around 0.05v
I don't have the reprogram kit fitted yet. It currently changes pretty quickly as the voltage clamp at the shift point isn't clamped at all. letting it shift at a clamp point will certainly result in a longer shift as you have pointed out.
Edited by BoostdR
  • 3 weeks later...
Ok so my 21A MAF crapped itself this morning. Lasted a few weeks longer then my last MAF. Have ordered the 'other' style Chinese unit. Will see how that goes. If that doesn't last I'll go to MAP&IAT with the EMU
Edited by BoostdR
MAP tune still needs the AFM pass through for the gearbox, unless you can emulate an AFM signal using the emanage? You could even run another different AFM.
I ordered some AFM's from my old supplier if you want to try one Matt, before totally giving up on them.
I think the way the EMU works it replaces the MAF signal with a blended output from the MAP and IAT so the car shouldn't know any different. Problem is I need a working MAF to log the output vs load for a starting point for changing over. I'm getting warranty on my 21A MAF so that help but still a pain.
Trying to guesstimate the MAF output vs MAP input from the logs. Should give a starting point.
I can't see why we can't use a 350z MAF with a conversion chart, would be as simple as using the 2nd MAF input and logging the voltage difference between them at all loads. Using this data to populate the Airflow output map.
PM me the price please, i wanna grab one mate.
Man what causes these things to fail ?
Not that mine has gone, but I'm expecting it will after a different turbo goes on.
Turbulence , erratic voltage ?
Are they supposed to blow to protect the engine ?
Have Nissan purposely designed them to limit modification possibilities to their cars after the Skyline Era..
I'm trying to get answers from tuners overseas.
Refer to this data at your own risk.
HDI cooler
Hypergear SS2
Full exhaust
OEM fuel system( does run lean in 3rd gear or above)
Boost approx 16psi
I'm now Running off the greddy map sensor which emulates the MAF. I cleared the error code from my faulty MAF and the car seems happy after a few hours of logging and road tuning with my O2 wideband. MAP is plugged into spare port in plenum and to option 1 socket on the EMU which you will need to enable in the software. Maps also should be changed to reference the MAP. I used relative pressure so I was working with actual gauge boost pressure.
I'm running partial E85 which will skew the figures but these settings have the car running quite ok. Well enough that I'll never to back to MAF. The response is great being MAP rather than MAF, no lag from accelerator pedal action to rpm change. I still need to setup acceleration enrichment and Intake temp compensation. The oem MAF is still sending the intake temp but the air density change is now not being compensated for. I would expect it to be off around 1.5-2% every 10degress still. So I'll update when I've set it all up. I'll chuck it on the dyno an do it properly.
Matt
post-49288-14441277037406_thumb.jpgpost-49288-14441277170826_thumb.jpgpost-49288-14441277272736_thumb.jpgpost-49288-14441277364457_thumb.jpg
This timing I found to work best with my Hypergear SS2. Gave a smidgen more useable boost from 2500-3000rpm. So it can keep up with normal traffic now when under 3000rpm
Edited by BoostdR
  • Like 1
Good, so you don't need much of a voltage input to emulate the AFM output to the stock ecu. Is there nothing the EMU won't do? Haha.
The original part number AFM's are still going in some cases, it's only the new part number Nissan sell that fails regularly. If I could find a stash of original AFM's they would be snapped up in no time. Until then the Chinese ones will have to do, unless you replace it with something else and tune for the differences. Ditching the AFM and running a MAP/IAT tune with AFM emulation like Matt just managed... Well that's even better. :)
What's even cooler Scotty is you can use the stock MAP sensor(up to its readable limit anyway). I just happened to have a 3 bar Greddy EMU sensor from my Starlet turbo build left over.
Some interesting findings using the MAP.
-Since I have a blend of E85 my MAF emulation voltages needed to be higher to get the right AFR's..as a result my shifts are now firmer. Another result looks to be that the gearbox now wants to be in 5th at anything over 50km/h... I'll take the firmer shifts thanks. When I adjust for my 1000cc injectors I think I'll over compensate so the AFM output voltage is skewed higher and then compensate with my pulse width correction.
I noticed the EMU doesn't want to output more than 5v however the OEM MAF will reach 5.11v. I could put a .10v positive offset on the MAF output line using a 10kOhmn potentiometer then take away .10v from the EMU MAF output map which would keep my AFR's correct but enable 5.10v output up top. Wish I knew if the shift time reduced/got firmer going from 5 to 5.11v.... Theoretically once I worked out the potentiometer set point(value/ohm) a simple resistor could used.
Edited by BoostdR
    • What does it look like with highway driving? And yes, I had a similar thought as Duncan. It looks quite similar in my Stagea and I have made myself accept it as normal. Might have to look into it some day
    • While I was waiting for the new parts to come in for the charge pipe and radiator I decided to do some turbo modification. The drive pressure (exhaust backpressure) was a lot higher that I thought it should be. For 32lbs of boost drive was 55lbs. The turbine housing is a 1.10AR and my turbo builder has suggested to go to a 1.25AR. To test if a larger AR would do anything to reduce drive pressure AND not spend any money I decided to hog out the divider in my current housing. I removed it from the inlet and the whole way through the housing.  After reassembly and testing it doesn't look like this modification did anything for reducing drive pressure or requiring more fuel (making more power). Oh well, it was worth a shot. We'll get some data at the track if it makes it past the 60ft. I also machined a $7 shift knob off Amazon to fit my Stillway shifter since I didn't like the Stillway shift knob. Next on the list was the radiator replacement and fabrication of a new intercooler tube that had no silicon coupler. No pictures of this - I was short on time each night after work to get this done and didn't stop to take pictures.  Next was to get the clutch disks out and replaced. Previously when installing the dogbox I had ordered a set of the same sintered iron disks I had been running because I switched to the 26-spline input shaft. I thought it was odd that they didn't have any markings or brand name on them like all my old disks had but installed them anyway. At the track I could not get the clutch to lock up using my normal strategies. After two track nights I reached out to the clutch manufacturer and ask their thoughts. They said they had to switch the material out because they were having trouble getting the original material and that this new material would not take to being slipped very well.  So out with the first set of 26-spline disks and in with the correct material 26-spline disks. While I had the trans out I added an inspection/service hole. I've wanted one of these for a while. Now I can have a look at things and change the front cover shimming when needed (clutch wear). I hustled and got the clutch change done in a few hours on a Saturday. Hopped in the car and drove home. On the way home I did a 1-3 pull. When shifting from 2nd to 3rd the core plug in the back of the cylinder head popped out and dumped all the coolant. Thankfully I was only 30 seconds from home and coasted it there. Datalog showed nothing unusual and 2.5psi of coolant pressure. That plug has been in there since 1992 but I guess it worked its way out. Pulled the trans AGAIN and replaced the plug, JB welded it in, and made a brace. Also deleted the head drain I had added in during the bearing issue fiasco.  I am currently changing my boost control plumbing to make it cleaner. After that is done I'll make another attempt at getting past the 60.
    • Are you 100% sure this isn't tune related?
    • 140-150 across the board. At this point hoping the grounding harness fixes it. My grounds are all tied to the chassis and none to the battery. For SR and KA that’s never been a problem for me but had a few other guys here and Reddit who told me RB really like a very solid ground setup tied to the battery so going to try that next, I’m stumped if that doesn’t do it. Never had a car have spark and fuel and not fire off before. Only thing I can think is the spark is intermittent/weak because of grounds nothing else really makes sense at this point
    • I am having close to the same issue. Can you help me with what wire you grounded to get your pump to trigger?
