Hey SAU, The time has come for me to move on from my R33 and invest in a work ute.
Up for sale now is my 1996 Series 2 GTS-T (manual)
Since buying this car off a member of this website who imported this car in 2004 and sold to me in 2010 I have treated it like a brand new car.
It has been well taken care of and every maintanence issue has been followed out during my ownership.
I was an extremely fussy buyer at the time and this was the standout r33 at the time.
Currently the odometer sits at 155,944 km
Previous owner has kept all documentation/reciepts of his maintanence as I have also for the following parts for proof.
Rego untill feb 2013, RWC can be arranged with the buyer or sold without. As I dont think it will need much besides the usual new windscreen etc.
Mods/work to this car include
100,000km service done
Tinted windows
Turbo timer
Exedy Heavy duty clutch
NGK Iridium spark plugs at around 135,000km
Tein flex coilovers & 350z 17" rims
Brand new alloy radiator and hoses fitted about a year ago
Brand new yellow jacket coils fitted a few months ago
Brand new slotted rotors for front and back along with new QFM performance brake pads also front and rear which were fitted last week
Engine oil has been changed on time every 4000-6000km, using Motul 8100 (garage is full of empty bottles) and a few other highly recommended oils from the goods on oils thread.
Clutch/brake fluid bled and changed
Paint is in excellent condition, shines bright while clean. Has a few tiny stone chips on driver door and a small key mark on rear left panel but not very noticable.
I have taken extremely good care during my time with this car, letting it warm up or driving very low rpm while cold for every drive. Always garaged and treated like a new car.
I am not after swaps unless you happen to have a BT-50 in immaculate condition.
Great car which has never let me down.
Not after top dollar as I already have my target reached for my new car and am in need of a work ute asap.
If you have any questions or offers please feel free to PM me I will be checking regularly for a fast reply.
I am located in Seaford, Vic and i'm more than happy to arrange a meet up if you are within reasonable range.
Price: 6500 ONO without RWC, If RWC is required then I can arrange an inspection.
Phone : 0414069029 my name is Sam. If i cant answer please leave an sms and I will get back to you.
https://www.sau.com.au/forums/topic/421237-1996-series-2-r33-gts-t-vic/
    • HyperGear. Just get a high flow of the stocker. Good, reliable, and should bolt on. Yes it will want things like a retune once done, so you need to factor this in to your spend too.
    • Hi. Iam looking for some "cheaper" bolt on turbo on RB25DET NEO. I do not want "big" power just better reliability than the stock turbo which is "fot now" good but is old and i do not think it has "easy" life. One the Skyline here running some "temu" china Turbo but i dont trust those... Thanks!
    • Hi guys, Making some space/cleaning up. A whole heap of random OEM R33 GTR parts and other random bits and bobs. I will update this thread as I go. Parts are located in Moorebank NSW 2170. Pickup preferred but will post at buyers expense. Prices are negotiable. If they don’t sell it will go in the bin. Item 1: BOV return pipe. $40 Item 2: RB26 cam gears. $20 Item 3: R33 GTR torque split, oil temp, boost centre gauge. $100 Item 4: RB26 fuel rail x 2. $20 each Item 5: RB26 Recirc valves. $50 Item 6: OEM upper front arms. $20 Item 7: Royal Purple Max Gear 75w-140 1 quart/946 ml x 5. $50 each or 5 for $200. Item 8: OS Giken 80w-250 diff oil 1 litre. $25 Item 9 Eibach springs. ers-11-140-60-0140. $100 https://www.streetfx.com.au/eib140-60-0060-eibach-ers-140mm-length-x-60mm-id-coil-over-spring?_ga_campaignid=22235933977&_ga_adgroupid=180146800292&_ga_keyword=&_ga_device=m&_ga_target=pla-295238231169&_ga_locint=&_ga_locphy=9071723&_ga_matchtype=&_ga_network=g&_ga_device=m&_ga_placement=&_gcl_id=CjwKCAjwlt7GBhAvEiwAKal0cvkVE_hstv24cDiaICsIk1oznH9zAoJf3By6vR3Tpe7jmByqM6JFHBoCZYAQAvD_BwE&gad_source=1&gad_campaignid=22235933977&gbraid=0AAAAADPiTbo1xAuvnjIWWYnezivf-BUSY&gclid=CjwKCAjwlt7GBhAvEiwAKal0cvkVE_hstv24cDiaICsIk1oznH9zAoJf3By6vR3Tpe7jmByqM6JFHBoCZYAQAvD_BwE
    • That's kind of what I was getting at saying you'd be here soon regarding length etc being able to add additional restriction.  My assumption (possible donkeys of you and mption) is that the length of hose to an oil cooler, and back, isn't going to be that huge of a loss. Typically you're talking about 1.5m of total length. And so far everyone in our world hasn't had issues with oil not being able to get to a cooler and back, it's more been, how the heck do we get the oil out of the head and back down to the bottom? I'd nearly hazard a guess the biggest issue people have with oil cooling and oil supply, is being able to get the heat out at the cooler itself (not enough air flow, too small of a cooler etc) Also, when people mount them wrong and make really awesome air traps so they've dramatically diminished the cooling capacity.
    • I will rebutt this and the preceding point from Dose....but without doing any calcs to demonstrate anything and without knowing that I am right or wrong. But... The flow capacity of a fluid transfer system is not limited by the smallest orifice or section of conduit in that system, unless it is drastically smaller than the rest of the system. OK, I use the word drastically perhaps with too much emphasis, but let's drill down on what I really mean. The flow capacity of the system is the result of the sum of the restrictions of the entire system. So, to make an extreme example, if you have a network with 3" pipe everywhere (and let's say a total length of only a few metres) and that 12mm ID restriction of the oil filter connection being the obvious restriction, then for any given amount of pressure available, the vast majority of all the pressure drop in the system is going to occur in the 12mm restriction. But.... increase the length of the 3" pipeline to, say 1000m, and suddenly the pipe pressure loss will likely add up to either be in the same order of magnitude, possibly even exceeding that of the 12mm restriction. Now the 12mm restriction starts to matter less. Translate this to the actual engine, actual oil cooler hose sizing, etc etc, and perhaps: The pressure loss caused by flowing through the narrow section (being the 12mm oil filter port, and perhaps any internal engine oil flow pathways associated with it) is a certain number. The pressure loss through, say, -12 hoses out to the cooler and back is negligible, but The pressure loss through -10 hoses out to the cooler, at the exact same length as the above, starts to become a decent fraction of the loss through the 12mm stuff at the filter port. Maybe even it starts to exceed it. I could actually do these calcs if I knew 1) how much oil was actually flowing in the line, 2) gave enough of a f**k to do things that I hate doing for work, voluntarily for a hypothetical discussion. Anyway - I reiterate. It's not the narrowest port that necessarily determines how much it can all flow. It is the sum. A long enough length of seemingly fat enough pipe can still cause more loss than a semmingly dominant small bore restriction.
