Looking the goods mate. :-)
My GTR has a spun big end (pretty sure).. so I'm in for a rebuild too.
Wish I could have the shiny goodies you got.
Ah well, beggars can't be choosers.
Good luck with the build mate, damn clean silver R you have too.
spun big end yeah that sucks .
at least yours will be cheaper then my build you can keep it 2.6L i had no choice but to upgrade .
while doing the build i thought better make it good its the only time ill ever rebuild to this extent lol
cheers for the support good luck with your build and making shit shiny :)
haha, I don't like shiny sh!t.
They look good.
But I like black.. and brushed surfaces, chrome isn't my thing.
Well - because I'm lazy I will be keeping my '26.
If I had an engine crane I'd be doing an RB30 build. HAHAHAHAHAHA.
Goodluck man, can't wait to see vids. ;-)
  • 1 month later...
so tomorrow im dropping the sump off to be welded up as it has a small crack,
also dropping the head in to be reconditioned.
getting new tomei valves and springs fitted , head shaved and acid washed.
so when i got the block back the first thing i wanted to do was paint
only question was what colour ?
kept it the factory black nice and stealth but clean .
Edited by jimbob32
waiting on the head to get done
for my nitto oil pump to turn up .
buying a garrett T04z next week and turbo smart 45 mm gate
should have the sump back in a week or so and i can re assemble and chuck it all togeather.
need to buy a good twin plate clutch and some injectors but its not long now before this motor can go back in and head to get a dump pipe made up and get tuned .
so excited now i know the car will be ready for summer iv got all the cash ready to go :)
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
