Sierra stage 1 turbo
Scotty dump
Scotty 3" front pipe
Nismo exhaust
Plenum spacer
Scotty actuator mod
Hdi front mount
Transgo shift kit
Turbosmart boost t
I do have a nismo ecu but it isn't fitted as it was running to rich. It will be waiting till I have money to do my emanage
Think thats it haha
sh###t you be running 13eents easy, while i hope for a 14 flat
my mods
dump pipe
custom 3" exaust
shift kit
custom intake pipe
14.1 with these mods 1.9 60 foot
I'm really hoping so. I need a new BOV so hoping that doesn't effect me to much, its bleeding off a bit up high. Also really need an intake pipe to get the most out of my setup. But we will see how we go.
Well not exactly what I had hoped for, 14.02 @161km/h I hit boost cut twice on tgis run. So it should have been a 13 easy. I had boost wound down as low as possible so not sure what to do next. Every other run hit cut a bunch more times so was much slower.
Took the car to Hiddenvalley last night, managed a 13.6 at 102 so still doing the same mph, couldn't get my 60 foot under a 2 seconds, very very slippery! They just had scrapped the rubber of and re layed vht hopefully when they get more rubber down it will be better! Plus side I've managed to get my reaction down to .006 so managed to do a number of .406 reactions
