For Sale: 1989 R32 GTR
Reason for sale: Need cash for investment
KMs: 114xxx on the clock
I've owned this car for about 4 years now, always been garaged and serviced every 5k with Royal Purple.
I bought the car from a mechanic (worked for SAS) who imported it in 2004. No money owed on the car, REVS checks are welcome.
The car came with some mods, and I've added a few. Tried to buy only the highest quality parts
All work done by Unigroup Engineering
Mods:
HKS Intake kit
HKS Cam gears
Garret 2859 -9 turbos
Tomei Expreme manifolds
Tomei Expreme dump pipes
Blitz front pipe
High flow cat
3 Inch cat back
Denso 650cc injectors
Bosch 040 in tank fuel pump
Exedy Heavy Duty clutch (clutch master and slave replaced with new OEM parts when this was done)
52mm Alloy radiator
Greddy Air Diversion Panel (discontinued item)
Whiteline sway bars front and rear
Ohlins suspension
Rear optional factory strut brace
Apex Power FC + hand controller
Profec Spec B II boost controller
4wd Controller
Greddy Informeter
Carbon weather shields
Nismo gear knob
Nismo seat covers
LED tail lights
Tinted windows
Full alarm system (windows wind them selves up), immobiliser, and kill switch
Sound system has also been upgraded with a pioneer head unit, front and rear speakers, and 10 inch sub
GTR-26R number plates will come with the car
Rolling on 17x9.5 Advan TC II wheels. These are very light weight with hollow spokes.
Making 270kw on a safe tune done by Unigroup Engineering. Will provide dyno sheet on inspection
The overall condition is very good for a car of this age. No dash bubbles, chassis rails are straight so it hasn't been fork lifted when coming over. AC works fine and pumps icy cold air.
There are a few factory options on the car that I haven't seen on other R32s
These are the emergency flare on the passenger kick panel and knee pads on the drivers side.
I also have a few original spares that will come with the car:
Manifolds
Dump pipes
Front pipes
Injectors
Turbos
Turbos rebuilt with steel wheels
Price: 23k neg
May swap for a Golf GTI or Evo 8/9 with suitable cash adjustment
Located: Wollongong
Contact 0401472321 or PM to organise a viewing
Edited by Cosa
https://www.sau.com.au/forums/topic/421522-r32-gtr-wollongong/
  • 3 weeks later...
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
    • Hi all,I already introduced myself in the Victoria section, but only saw this section now lol XD New to forums and new to skylines. Hoping to buy my new skyline within October
