The deposit issue is null and void by a stroke of luck, Not only was the car not ready yet, when I went in to the bank to organise a new bank cheque today, I found that the original deposit cheque had not been cashed yet.I cancelled it and called the dealer to say my patience had run out as politely as I could and he winged for a bit but then resigned his argument after a brief chat. He was ok and blamed his business partner for not calling me last week. Too little too late and the delay ended up working out for the better in the end.
  • Replies 114
Might have to organise a meet at Lane cove again!!
Cannot wait to get my thing back on the road again! lots of little problems sorted....then out to EC....I have a 12.9 to beat.
Eastern creek is something I want to do sometime, but pretty sure it would be the end of my turbo.
Baby steps Craig, you have to beat 13.8 from Dale and myself first before thinking 12s.
Congrats on the new purchase Matt. I know your wont be disappointed in the car, and I hope you can keep it looking as good as Chris did.
+1 for a meet for the Sydney guys, but I'm not organising it... :P
I can't believe anyone is doing 12's! That's solid..
:P
Baby steps???
Oh just let me pull up the handbrake half track so I don't go to fast on my first run....is that ok!!! Don't want to go to fast because that would be above the national speed limit of 110km/h!
P.s v-tard section is in another part of sau! B-slap to arec in next sighting.
Baby steps???
Do you even stagea brah?
Pull up the handbrake? Your doing it wrong.
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
