  • Replies 93
From memory
2Rsimo did a 11.98
Doughboy did a 12.06
Sam did a 12.9 something
I did a 13.11 something
Matt did a 13.4 something
Don't quote me on that - but I think I am close.
Here's me (disapointing)
R/T = .479
60' = 2.528
330' = 6.113
660' = 8.872
mph = 91.66
1000' = 11.178
ET = 13.118
MPH = 116.89
Km/h = 188.12
https://www.sau.com.au/forums/topic/42168-drag-combat/#findComment-863235
From memory
2Rsimo did a 11.98
pretty well spot on mate.. I managed a 12.9 new PB Woo hoo and took out the D.Y.O Class, Stacy also won the AWD6 class as well as finishing 1st in the series over all... Well done Stacy. Matt was happy with his new PB but Adrian was so pissed after red lighting against a car he could beat by 4 seconds.. Dam I feel for you bro..
I would like to also say thanX to the SAU guy's for sticking around in the freezing cold to support both Stacy and Myself to the very end of the night...
We where on a mission bwahaha.... B-Man knows what I mean.. was good to finally meet you boys
https://www.sau.com.au/forums/topic/42168-drag-combat/#findComment-863427
Sorry i missed it guys, have a killer cold and i know how cold WSID can get.
Well done to all!!
Sam, thought of NOS? you could give Adrian a run for his money :)
Nah no NOS dude. I like my car as is and they way it's slowly developing.. Besides the NOS theory has been proven I think.. (It works and thats 2rismo's realm) Adrian you fcuked up but that's just racing dude, we all do it but that doesn't mean your not a champ mate...
https://www.sau.com.au/forums/topic/42168-drag-combat/#findComment-863508
Was concentrating on too many other things when i should've been disarming the gas and launching in 2nd. Still had a good day though. Ran another 11 and the new tyres worked a treat (1.694 60').
Back to the drawing board though... Need it to rev through the gears quicker...
:):P:D
Adrian
https://www.sau.com.au/forums/topic/42168-drag-combat/#findComment-863512
Sorry I didn't stick around for the presentations... I left at 7pm cos I couldn't take it anymore... I didn't sit down at all the entire day... I was completely buggered...
And I had to go out for dinner afterwards too!!! I fell asleep during the movie we started watching at 12:30pm... Why doesn't that surprise me :)
Congrats to Stacey (you're a girl) and Sam... Congrats to Doughboy for running a 12 flat on his first outing (very rare), and Congrats to Buster for................. bringing the membership forms and stickers :D
I'll be out there with you guys next year for sure when my car is ready :P Watch out Stacey ;)
https://www.sau.com.au/forums/topic/42168-drag-combat/#findComment-863532
Just WHAT goes on in the Media box upstairs, Andrew?!?!!?!
Adrian
All the promo girls change into their skimpy bikinis and serve us sandwiches, soft drinks, water, tea/coffee all day along with back rubs and massages with scented oils.
https://www.sau.com.au/forums/topic/42168-drag-combat/#findComment-863538
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
