Pretty sure if you did your research bud you'd find that your insurance wouldn't cover any accidents if you're using your ride as a business venture.
Goodluck with it though......lotta cash to throw away if someone writes it off for you >_<
https://www.sau.com.au/forums/topic/421967-drive-r35-gtr/#findComment-6792464
Insurance companies dont cover track use which is unfortunate, because id be taking it straight to mallala :P
https://www.sau.com.au/forums/topic/421967-drive-r35-gtr/#findComment-6794496
$300 to putter around town for an hour? Yeah nah. Maybe $150 for that. Maybe. And I'd want a hot topless blonde with huge tits sitting next to me for that price if all I'm doing is puttering around town.
$300 I guess would be okay if I get to thrash it around some of my favourite hills roads at night.
$550 would be acceptable only if I got to belt the ever living shit out of it for a couple 15 minutes sessions on track.
https://www.sau.com.au/forums/topic/421967-drive-r35-gtr/#findComment-6801271
PM me what roads you have in mind. Got a mate looking to start a business due to retirement and he is looking to get a 35 for WA in around a week. Put the two together and there might be some hope :P Plus the one he is looking at getting from WA is already some what modified pulling just under 600awhp. I reckon he might be keen on hills runs but no way would he do a track hire etc. See how we go, speeding fines would be your own kettle of fishies :D
https://www.sau.com.au/forums/topic/421967-drive-r35-gtr/#findComment-6801273
Surely it would work similar to a hire car company lending out the car to someone? maybe they'd charge you a bit extra to insure you/cover the excess costs. Otherwise i can imagine the general excess for an R35 GTR insurance isn't small...
Contact an insurance broker to see if it is viable or not
https://www.sau.com.au/forums/topic/421967-drive-r35-gtr/#findComment-6802131
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
    • I suppose it was relatively stock too, the JZ motor handle most mods thrown at them without even breaking a sweat
